Attiny2313 fuses help!!
by aditya_g8 on Sun Mar 22, 2009 8:41 am
What are the fuses to be set when programing a SPoke POV??
aditya_g8
Re: Attiny2313 fuses help!!
by adafruit on Tue Mar 24, 2009 9:11 pm
look in the makefile
by kayrock66 on Sat Mar 28, 2009 12:00 pm
The code can be modified to change the internal clock speed without requiring any particular fuse setting. This would get rid of the extra step of setting fuses.
kayrock66
by vvs on Fri Oct 02, 2009 2:44 am
...I have such question :
..in a project minipov was talked : "...Note: if you are trying this out with a new microcontroller (i.e. not from a kit) you'll need to burn the fuses first, otherwise it won't work right and might not be programmable. Run make burn-fuse before you type in make program-minipov, while the minipov is powered and connected to the serial port. You might have to do it a couple of times if its failing. ..."
In the project of Spok POV is it needed to conduct such action ?
vvs
by kayrock66 on Fri Oct 02, 2009 12:06 pm
Only if you bought your own microcontroller from a source other than LadyAda.
kayrock66
by vvs on Fri Oct 02, 2009 12:27 pm
thank you
...stop.
if microcontroller from a source other than LadyAda, what actions do need to be executed before programming?
vvs
by haak on Wed Oct 02, 2013 2:40 pm
I checked makefile but there are some strange fuses and even efuse is missing!
please could you write down avrdude arguments for me (us)?
regards
haak
by EEdy on Tue Feb 18, 2014 12:00 pm
i have the same questions here, what do i need to do if i bought a chip from somewhere else?
EEdy
