Hello all,
I'm having trouble uploading image to my Spoke POV through pararell port dongle, I installed the giveio.exe then set port type to parallel, port = lpt1, wheel size = BMx, hub size = 10, comm port delay = 5000, and finally clicked test port --> press "ok" and get a prompt "failed to open the port".
I also tried Lpt 2 and 3 then click 'connect' and get the following message---> "failed to open the port"---> "failed to communicate with spokepov! you may want to try increasing the communication delay"
I did a search on this forum related to this problem and found the follwing link:
http://forums.ladyada.net/viewtopic.php ... gle#p40520
the reply from Ladyada: " mm, there's nothing that should have changed. be sure to do a hard reset, do the tests on the dongle with a multimeter if you can. be sure you ran the .bat file that gives parallel port access, etc"
quote: be sure you ran the .bat, what .bat file and where can I find this file?
When uploading image from computer to Spoke pov, should the batteries be installed at the SpokePOv or not?
pease help...
SpokePov parallel port dongle not working
Re: SpokePov parallel port dongle not working
is this from a kit or did you build it yourself?
Is working now...mess around with pararell port settings and it worked.
im goin thru the same thing, wont communicate!
Need more detail than that.
Adfruit kit or roll-your-own?
Operating System?
Have you gone through all the steps here? http://www.ladyada.net/make/spokepov/software.html
Any error messages displayed?
Operating System?
yea mine just quit being read by the program, I cant figure it out , they are the spoke povs, I used to be able to change the graphics, Im going try again...
we can help you better if you answer these questions
Adafruit kit or roll-your-own?
Operating System?
Operating System?
