AVR Dragon + SpokePOV
by haak on Wed Oct 02, 2013 5:10 pm
Could be used AVRdragon for programming SpokePOV?
haak
Re: AVR Dragon + SpokePOV
by adafruit_support_rick on Thu Oct 03, 2013 10:14 am
You would use the SPI programming method, as documented here:
http://www.atmel.no/webdoc/avrdragon/av ... ption.html
by haak on Thu Oct 03, 2013 11:38 am
I did it like this but spokepov.app (1.4) failed to open the port.
But with avrdude it's normaly working and I flashed spokepov.hex. and I hope with right fuses (-U lfuse:w:0x64:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m0)
I'm on osx 10.8.5 but i tried also 10.6.2. Still with same result.
Could you please share with me default hex files for 2313 and eeprom? I would like to burn it all with avrdude to see if everthing is ok.
regards
haak
by adafruit_support_rick on Thu Oct 03, 2013 12:48 pm
Oh - the spokePOV.app won't work with the Dragon. It's looking for a USBtinyISP.
The hex file is linked on the tutorial downloads page.
Here's the direct link:
http://www.ladyada.net/media/spokepov/s ... re1_01.zip
by haak on Thu Oct 03, 2013 2:32 pm
and does this .hex includes also some default pictures?
kind regards
haak
by adafruit_support_rick on Thu Oct 03, 2013 3:00 pm
I believe it does, yes.
by haak on Thu Oct 03, 2013 3:19 pm
I flash it again with avrdude and those fuses (-U lfuse:w:0x64:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m0)
I'm right?
haak
by haak on Thu Oct 03, 2013 4:11 pm
or -U lfuse:w:0xe4:m -U hfuse:w:0x9d:m
haak
by adafruit_support_rick on Thu Oct 03, 2013 4:15 pm
Where did you get those fuse values? Those aren't the ones in the makefile.
The makefile burns these fuse values: -U lfuse:w:0xe4:m -U hfuse:w:0x9d:m
Also, I looked at the source code, and it does not contain any default pictures. So the .hex file will not have pictures after all.
Sorry. :(
by haak on Thu Oct 03, 2013 4:38 pm
thanks for fuses.
good to know, that there're no pictures in .hex
I have to build serialISP and find some old PC.
could you share with me schematic for your serial ISP dongle?
haak
by adafruit_support_rick on Thu Oct 03, 2013 5:33 pm
Everything available is linked on the tutorial downloads page.
The USBtinyISP kit is only $22.
