This is what I did:
Imported one image per bank, adjusted them, wrote them & verified them. Now when I start the SpokePOV app it says that I only have two banks! Any ideas where the last two have gone? If it matters I used the windows version, with 32 frames before switching and Mirror on. I tried the same on my second one with the same result, but won't test with my third one...
My SpokePOVs have "lost" two banks :-(
Help Lost 2 Banks
I tried writing empty images to the two banks, disconnected and reconnected and it still only shows two banks.
Any ideas?
Any ideas?
I'm getting this problem also. Seems to be connected with mostly full wheel graphics. Connected with particular image patterns. For example, my flag graphics cause the problem. But I was able to get all 4 banks back by writing an empty image. Have done this back and forth many times.
But now with the image of the parrot rockin' the microphone, I'm stuck. Erasing banks 1 and 2 still doesn't bring back 3 and 4. Can you take a look at this Ladyada in your PC program?
I've been poking around with my logic analyzer and while I don't completely understand how the memory discovery works, it looks like as a side effect of a bug has some a strange behavior.
If the first byte of the EEPROM (0x0000) happens to be the same as the 1's compliment of the first byte in bank 3 (0x0800) then the PC client thinks that the SpokePOV only has 2 image banks.
When the client is working right, will it detect larger EEPROMs and show more banks in the user interface? How many will it support? I see it scanning up to address 0x4000.
I installed a 256kb device, PC client hung. Modified uC firmware to mask MSB of EEPROM address, PC client shows (properly) 16 banks.
Write some images to the first 6 banks, PC client later shows only 8 banks. So it seems the same bug that causes the PC client to incorrectly show 2 of 4 banks depending on image content, later shows 8 of 16 banks depending on image content.
This has been an ongoing issue. It's image content related so it doesn't hit everyone. Because of the hobby nature of the product I think Lady Ada is just letting this problem ride.
You can undo the problem by changing the data in the banks you can still access. Can't be more specific than that.
OK, cool. can someone send me a dat file that seems to prove effective? I've cleared the available banks, disconnected then reconnected to no avail.
Is there any other software that would allow me to directly access the database? ... Perhaps there's a way to manually zero out the problem data.
my e-mail is ajmcrazy(at)gmail(doooot)com
