๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Test sequence fails
Test sequence fails
by Keldin on Thu Jun 12, 2014 11:15 am
Just finished a spokepov and on inserting the batteries (2 batteries - yellow LEDs) it starts the test sequence on the battery side and 2 LEDs light up but the 3rd one does not and the sequence stops and I get a single lit LED on one side and 2 on the other staying on.
Does the final lit LED locations provide some hint as to the fault?
I cannot see any bad solders and tried replacing the 3rd LED that failed to light without success.
What should I be looking for
Keldin
Re: Test sequence fails
by adafruit_support_rick on Thu Jun 12, 2014 3:12 pm
Please post clear, detailed pictures of both sides of the spokePOV, showing your assembly and soldering.
by Keldin on Thu Jun 12, 2014 5:19 pm
First 3 of 6 pics.
Keldin
by Keldin on Thu Jun 12, 2014 5:21 pm
Last 3 of 6 pics.
Keldin
by adafruit_support_rick on Thu Jun 12, 2014 9:53 pm
That looks pretty good. There's not a lot that can go wrong with these. Make sure that all of the chips are installed the right way around. It looks that way from the pictures, but there are a few that I can't see. Double-check the LEDs, too. The flat sides should all be oriented the same way.
Unfortunately, the lights left on after the self-test aren't really a diagnostic. They don't tell you what's wrong.
by Keldin on Fri Jun 13, 2014 5:40 am
Everything is the correct way around.
The LEDs all seem good and I swapped out the 3rd one.
Does the fact that it's the 3rd led in the sequence that fails to light and the sequence is interrupted provide any clue as to where to look for failed parts? If not then from what you say there's really no option but to bin it which seems like a waste.
Keldin
by adafruit_support_rick on Fri Jun 13, 2014 10:32 am
It seems like the problem would have to be in either IC3 or IC4. You can try swapping those out, if you like. Meanwhile, we should probably send you a new kit. Please email support@adafruit.com with a link to this thread for a replacement spokePOV
by phenoptix on Fri Jul 25, 2014 9:29 am
Managed to replicate (and solve) the problem as described here.
The LED pattern as described appeared on one I've just built and kitted myself. The firmware on the ATTiny2313 used was the "hacked" version from the software page. I was able to get it to "go away" by waving a magnet in front of the hall effect sensor.
Replacing the code on the ATTiny with the v1.1 standard .hex file returned the LED test as described in the build instructions.
phenoptix
