๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
New here, working with 5mm Neopixels
by ryanaus on Mon Aug 25, 2014 7:46 am
I'm able to get the neopixels to display the Adafruit strandtest easily but was wondering about how I would go programming so that separate pins on the arduino can send different bits of data to different strands of individual neopixels that I've daisy chained together. Would I need a decoder or something similar to achieve this? Even if someone could point me in the rigth direction, I haven't been able to find any good examples of something similar to what I'm trying to do.
ryanaus
Re: New here, working with 5mm Neopixels
by adafruit_support_bill on Mon Aug 25, 2014 8:00 am
To control different strips from different pins, just declare each strip separately, with a unique name and a unique pin:
Adafruit_NeoPixel stripA = Adafruit_NeoPixel(60, PIN_A, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel stripB = Adafruit_NeoPixel(60, PIN_B, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel stripC = Adafruit_NeoPixel(60, PIN_C, NEO_GRB + NEO_KHZ800);
by ryanaus on Mon Aug 25, 2014 8:07 am
Doing it that way is it possible to have the one pattern displayed on the strand connected to PIN_A and a completely different pattern displayed on the strand connected to PIN_B. If it is possible, how? I tried modifying the existing functions so that one is set for pin_a and the other for pin_b but that didn't work. They still display the same patterns.
ryanaus
by adafruit_support_bill on Mon Aug 25, 2014 8:13 am
With strips defined as above and connected to different pins, any commands on stripA will go to stripA only. Commands on stripB or stripC will affect only those strips as well.
by ryanaus on Mon Aug 25, 2014 8:16 am
Alright, I've been up all day so I'm sure its something simple I'm forgetting. Cheers for the help mate.
ryanaus
by adafruit_support_bill on Mon Aug 25, 2014 8:27 am
If you post your code and a photo or wiring diagram, we'll see if we can spot the problem.
by ryanaus on Mon Aug 25, 2014 8:33 am
Was able to get them working perfectly, just forgot to change the colour values for the second strand. Think it's time to have a break haha. Thanks for the help!!
ryanaus
