๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
SpokePOV Not Working
by jwb on Tue Aug 26, 2014 1:49 pm
Hi guys,
I soldered up a SpokePOV and when i put the batteries in, they get hot and the LEDs don't light up. I was concerned I put the LEDs in wrong because a lot of people did. I put the long leads toward the outside of the PCB.
jwb
Re: SpokePOV Not Working
by jwb on Tue Aug 26, 2014 2:33 pm
I figured out that only the battery next to IC8 heats up.
jwb
by jwb on Fri Sep 05, 2014 10:53 am
I could still use some help with this. Any suggestions for powering my SpokePOV?
jwb
by adafruit2 on Wed Sep 10, 2014 12:24 pm
Hiya, it looks like only 2 of three battery holders are in place, is there a reason you didnt install the second battery holder? also, did you cut the trace for the third battery?
see
https://learn.adafruit.com/system/asset ... 1396859314
adafruit2
Site Admin
by jwb on Wed Sep 10, 2014 12:41 pm
Oops, I put it in the wrong spot? Also, I only got 2 battery clip sets with the kit. I assumed you used 3 for blue, but this one is red.
So I should desolder the clips and resolder them in the other location?
jwb
by adafruit2 on Wed Sep 10, 2014 12:48 pm
yep! just make it look like the photo, use a big soldering top to desolder, and pliers to carefully remove :)
adafruit2
Site Admin
by jwb on Wed Sep 10, 2014 1:40 pm
I wasn't able to get the clips out so I jammed in a plastic 1xAA holder in there and soldered it into place. It worked! Thanks for your help!
jwb
cron
