๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
SpokePOV doesnt work
by thisisvlad on Sat Aug 29, 2015 8:25 pm
I bought 4 of these kits and none of them seem to work. clearly i did something wrong on all 4 of them :-/.
i have 2 yellow ones and 2 blue ones. when i put the batteries in, they go through the test sequence and each LED lights up in turn. i assembled the usbTiny and programmed each of them. that seemed to work because afterwards i was able to "Read from SpokePOV" and the image returned correctly. However, spinning my eheel does nothing. i only see the two test LEDs on and nothing else. also, my batteries exploded on one of the kits... i guess i was supposed to take the batteries out while programming it?
Here are photos of each side of the 4 kits: https://goo.gl/photos/Nnt4T4E4psEf9LrH9
any thoughts on what i messed up?
thanks!
thisisvlad
Re: SpokePOV doesnt work
by adafruit_support_bill on Sun Aug 30, 2015 6:32 am
If you are able to program it and read the image back, then they are probably assembled correctly. It sounds like your problem is with the triggering circuit.
Make sure that the magnet is close enough to the Hall sensor.
Also make sure that the magnet is facing the right way. It will only work if the South pole of the magnet is facing the sensor.
by thisisvlad on Sun Aug 30, 2015 6:47 pm
awesome.. thanks so much for the advice!! :)
unfortunately, my bike is at my friend's house now, but i will get a chance to try this tomorrow night when i go there. this will be my last chance to try anything before i leave for burning man, so if i don't get it working then, it'll be $200+ down the drain plus a bunch of time wasted. any other tips on things i can try if the magnet thing doesn't do the trick?
thanks in advance for any additional thoughts!
thisisvlad
by adafruit_support_bill on Mon Aug 31, 2015 7:56 am
You can also try manually triggering it. If you short the sensor input (pin 7 on the ATTiny processor) to ground briefly a few times, you should see the leds sequence through the image.
