Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days. On MLK Day no orders will be shipped.
Lidar-Lite v3
Lidar-Lite v3
by asmartvol on Fri Oct 29, 2021 12:05 pm
I need to make this waterproof - suggestions on what to do and/or what not to do with the glass? I can put a different enclosure around it, just more concerned about not causing issues in accuracy. Thanks!!
asmartvol
Re: Lidar-Lite v3
by adafruit_support_bill on Fri Oct 29, 2021 1:09 pm
We have not tried weatherproofing these. At a minimum, anything in front of the glass would need to be transparent to the laser wavelength (905 nm nominal).
Garmin support can likely give you some more specific advice: https://support.garmin.com/en-US/?produ ... tab=topics
Re: Lidar-Lite v3
by asmartvol on Fri Oct 29, 2021 2:00 pm
Unfortunately, Garmin said that distribution takes on full responsibility of support. I'll trial and error and figure some things out, thanks for the info that you do know!! Is the "one purchase per customer" going to possibly change on this product?
asmartvol
Re: Lidar-Lite v3
by adafruit_support_bill on Fri Oct 29, 2021 2:23 pm
We hope that the supply-chain issues ease up soon. But for now, these devices are in very short supply.
Re: Lidar-Lite v3
by asmartvol on Mon Nov 01, 2021 1:53 pm
I actually have the exact same question for the ToF sensor (4000mm).... would that be 905nm, as well? I appreciate your help!
asmartvol
Re: Lidar-Lite v3
by adafruit_support_bill on Mon Nov 01, 2021 2:43 pm
The VL53L1X ToF sensor uses a wavelength of 940 nm as described: https://www.adafruit.com/product/3967
And as noted on the first page of the datasheet it does work behind a variety of cover-window materials: https://cdn-learn.adafruit.com/assets/a ... l53l1x.pdf
