hello
i recently change my tube and psu . i have a 50w tube and a 60 w psu.
cutting works perfect ...engraving....not so well . i get "ghost" lines. it is like the laser fires 3 short times before the actual engrave and 3 short times after. ex: when i am engraving a square. i get three thin lines on both sides...if i engrave a line i get three points
i have checked the belts, motors, mirrors, lens, cables ....still nothing
on x swing the "effect" is in both sides, on y swing , the same only vertical, unilateral left/right , the same left or right
this happens only at speed higher than 60mm/s
thank you
engraving issue
