3x4 Matrix Key pad used with the Raspberry Pi
rainierez
Post by rainierez »
I recently picked up one of the 3x4 matrix keypads as part of a project with my RPI. There really wasn't any existing code specific for the RPi and or python so I wrote up a script for it. I've included 2 versions. One uses the straight RPi's GPIO pins and then the one I needed was to use the MCP23017 chip. This uses the already existing python library from Adafruit's.
Here is my blog post with some details: http://crumpspot.blogspot.com/2013/05/u ... berry.html
RPi GPIO verion:
# Python Library for 3x4 matrix keypad using
# 7 of the avialable GPIO pins on the Raspberry Pi.
# This could easily be expanded to handle a 4x4 but I
# don't have one for testing. The KEYPAD constant
# would need to be updated. Also the setting/checking
# of the colVal part would need to be expanded to
# handle the extra column.
# Written by Chris Crumpacker
# May 2013
# main structure is adapted from Bandono's
# matrixQPI which is wiringPi based.
# https://github.com/bandono/matrixQPi?source=cc
import RPi.GPIO as GPIO
class keypad():
    # CONSTANTS
    KEYPAD = [
    [1,2,3],
    [4,5,6],
    [7,8,9],
    ["*",0,"#"]
    ROW         = [18,23,24,25]
    COLUMN      = [4,17,22]
    def __init__(self):
        GPIO.setmode(GPIO.BCM)
    def getKey(self):
        # Set all columns as output low
        for j in range(len(self.COLUMN)):
            GPIO.setup(self.COLUMN[j], GPIO.OUT)
            GPIO.output(self.COLUMN[j], GPIO.LOW)
        # Set all rows as input
        for i in range(len(self.ROW)):
            GPIO.setup(self.ROW[i], GPIO.IN, pull_up_down=GPIO.PUD_UP)
        # Scan rows for pushed key/button
        # A valid key press should set "rowVal"  between 0 and 3.
        rowVal = -1
            tmpRead = GPIO.input(self.ROW[i])
            if tmpRead == 0:
                rowVal = i
        # if rowVal is not 0 thru 3 then no button was pressed and we can exit
        if rowVal <0 data-blogger-escaped-or="" data-blogger-escaped-rowval="">3:
            self.exit()
            return
        # Convert columns to input
                GPIO.setup(self.COLUMN[j], GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
        # Switch the i-th row found from scan to output
        GPIO.setup(self.ROW[rowVal], GPIO.OUT)
        GPIO.output(self.ROW[rowVal], GPIO.HIGH)
        # Scan columns for still-pushed key/button
        # A valid key press should set "colVal"  between 0 and 2.
        colVal = -1
            tmpRead = GPIO.input(self.COLUMN[j])
            if tmpRead == 1:
                colVal=j
        # if colVal is not 0 thru 2 then no button was pressed and we can exit
        if colVal <0 data-blogger-escaped-colval="" data-blogger-escaped-or="">2:
            self.exit()
            return
        # Return the value of the key pressed
        self.exit()
        return self.KEYPAD[rowVal][colVal]
    def exit(self):
        # Reinitialize all rows and columns as input at exit
                GPIO.setup(self.COLUMN[j], GPIO.IN, pull_up_down=GPIO.PUD_UP)
if __name__ == '__main__':
    # Initialize the keypad class
    kp = keypad()
    # Loop while waiting for a keypress
    digit = None
    while digit == None:
        digit = kp.getKey()
    # Print the result
    print digit
RPi with MCP230xx:
# the MCP23008 chip via I2C from the Raspberry Pi.
# May 2013
from Adafruit_MCP230xx import Adafruit_MCP230XX
class keypad(Adafruit_MCP230XX):
    # Constants
    INPUT       = 0
    OUTPUT      = 1
    HIGH        = 1
    LOW         = 0
    KEYPAD = [
    [1,2,3],
    [4,5,6],
    [7,8,9],
    ["*",0,"#"]
    ROW         = [6,5,4,3]
    COLUMN      = [2,1,0]
    def __init__(self, address=0x21, num_gpios=8):
        self.mcp2 = Adafruit_MCP230XX(address, num_gpios)
    def getKey(self):
            self.mcp2.config(self.COLUMN[j], self.mcp2.OUTPUT)
            self.mcp2.output(self.COLUMN[j], self.LOW)
            self.mcp2.config(self.ROW[i], self.mcp2.INPUT)
            self.mcp2.pullup(self.ROW[i], True)
        # valid rowVal" should be between 0 and 3 when a key is pressed. Pre-setting it to -1
        rowVal = -1
            tmpRead = self.mcp2.input(self.ROW[i])
            if tmpRead == 0:
                rowVal = i
        # if rowVal is still "return" then no button was pressed and we can exit
        if rowVal == -1:
            self.exit()
            return
            self.mcp2.config(self.COLUMN[j], self.mcp2.INPUT)
        self.mcp2.config(self.ROW[rowVal], self.mcp2.OUTPUT)
        self.mcp2.output(self.ROW[rowVal], self.HIGH)
        colVal = -1
            tmpRead = self.mcp2.input(self.COLUMN[j])
            if tmpRead == 1:
                colVal=j
        if colVal == -1:
            self.exit()
            return
        self.exit()
    def exit(self):
        # Reinitialize all rows and columns as input before exiting
                self.mcp2.config(self.ROW[i], self.INPUT)
                self.mcp2.config(self.COLUMN[j], self.INPUT)
    kp = keypad()
    r = None
    while r == None:
        r = kp.getKey()
    # Print the result
    print r
Here is a demo usage script, just comment and uncomment the import lines to switch between the two versions.
# Demo script showing the use of the Python
# matrix Keypad library for both the Raspberry Pi
# GPIO and the MSP230xx I2C Chip set.
# Librarys needed:
# matrixKeypad_MCP230xx.py or matrixKeypad_RPi_GPIO.py
# Also needed is the Adafruit python libraries for the
# MCP230xx chips (Adafruit_MCP230xx.py) and I2C (Adafruit_I2C.py)
# May 2013
from matrixKeypad_MCP230xx import keypad
#from matrixKeypad_RPi_GPIO import keypad
from time import sleep
kp = keypad()
def digit():
    r = None
    while r == None:
        r = kp.getKey()
    return r
print "Please enter a 4 digit code: "
# Getting digit 1, printing it, then sleep to allow the next digit press.
d1 = digit()
print d1
sleep(1)
d2 = digit()
print d2
sleep(1)
d3 = digit()
print d3
sleep(1)
d4 = digit()
print d4
# printing out the assembled 4 digit code.
print "You Entered %s%s%s%s "%(d1,d2,d3,d4)
adafruit_support_mike
Re: 3x4 Matrix Key pad used with the Raspberry Pi
Awesome! Thank you for sharing!
