How fast can you read from an MCP23008?
by Keith_Henrickson on Sun Jun 11, 2017 11:41 pm
I'm running the following sample project on a Wiced:
#include "Adafruit_MCP23008.h"
static Adafruit_MCP23008 keys;
  // put your setup code here, to run once:
  keys.begin();
  // put your main code here, to run repeatedly:
  Serial.print("A:");
  Serial.println(millis());
  uint8_t row_selector[4] = {0xE0, 0xD0, 0xB0, 0x70};
  int row = 0;
  keys.writeGPIO(row_selector[row]);
  keys.readGPIO();
  Serial.print("B:");
And I get the following results:
A:2113
B:2116
A:2116
B:2119
A:2119
B:2122
Does it really take 3ms for the Wiced to read and write a total of 4 bytes?
Doing a rough calculation, that would be 333 scans/sec. At 4 bytes each, that's 1332 bytes/second, or 10656 bits/sec, about 1/10 the theoretical limit of I2C....
Keith_Henrickson
Re: How fast can you read from an MCP23008?
by adafruit_support_carter on Mon Jun 12, 2017 2:04 pm
Some of that time could be in the serial prints. Try storing the millis() values in variables and printing after the fact.
uint32_t start = millis()
// do stuff
uint32_t end = millis()
// serial print start/end as you wish
by Keith_Henrickson on Fri Jun 16, 2017 1:13 am
Thank you. I did remove everything except for a single read statment. I now have:
  keys.begin();
  keys.readGPIO();
However, I'm seeing a problem if I put it up on the scope (which yes, I should have done in the first place).
If you take a look at the first two screenshots, (3 and 4, in that order), it looks like a fairly normal write via I2C of address 0x20 (the chip address), it's address 0x09 (the base).
There is an extra transition on SDA that I'm not sure about. From the examples I've seen it should just go 1, and then SCL will follow. But it seems that a stop bit is being inserted.
Last edited by adafruit_support_carter on Mon Jun 19, 2017 10:42 am, edited 1 time in total.
Reason: inlining images to force order
Keith_Henrickson
by Keith_Henrickson on Fri Jun 16, 2017 1:22 am
Sorry, it took too many pictures to tell the story.
The bus is then idle for about 700ms (same line of code in my program still).
Then a whole new I2C transaction is started, of a READ from 0x20, which comes back with 0x00 and... a NACK? That looks to me in image 6 like the last bit is a 1. That's a NACK correct?
Keith_Henrickson
by adafruit_support_carter on Mon Jun 19, 2017 10:53 am
The other way around. The stop condition for I2C is: SDA goes high after SCL
Maybe. The ACK/NACK is the 9th bit. A 1 indicates an issue. Do you get that with every transaction?
by Keith_Henrickson on Sat Jul 15, 2017 6:51 pm
Yep, that's every transaction. I'm not sure why the WICED is complaining.
It hands me back the data, it's just REAAALLY slow.
Keith_Henrickson
by Keith_Henrickson on Sat Jul 15, 2017 9:05 pm
I just realized I had a Feather M0 datalogger laying around. Some of the pins I use on the WICED are occupied on the M0, but it works for simple I2C.
I get a MUCH better output using the same code:
A:8913
B:8913
A:8913
B:8914
A:8914
B:8914
A:8914
B:8915
A:8915
B:8915
Usually reads are completed in the same millisecond, even with my very crude and wasteful performance monitoring code.
Something is definitely up with the WICED. I'm not sure how to tell if it's something in my setup code, or if the microcontroller is sensitive to something wrong with my board design.
I have another WICED I could put pins on, if this is possibly a hardware problem on the WICED.
Keith_Henrickson
by adafruit_support_carter on Sun Jul 16, 2017 11:10 am
Are your running the same code on both the WICED and the M0? (post if so)
by Keith_Henrickson on Sun Jul 16, 2017 6:54 pm
Just reran to be sure what I was seeing:
  Serial.begin(250000);
  keys.begin();
  uint32_t start = millis();
  keys.readGPIO();
  uint32_t end = millis();
  Serial.print("A:");
  Serial.println(start);
  Serial.print("B:");
  Serial.println(end);
From the WICED:
A:2111
B:2122
A:2123
B:2125
A:2125
B:2135
A:2136
B:2138
A:2138
B:2148
From the M0 datalogger:
A:604
B:604
A:604
B:605
A:605
B:605
A:605
B:606
A:606
B:606
A:607
B:607
A:607
B:607
The WICED takes 10ms to do something that the datalogger takes < 1ms to do.
Keith_Henrickson
by adafruit_support_carter on Mon Jul 17, 2017 10:38 am
Weird. The timing isn't consistent on the WICED. Try running this slightly modified version of the code on both and see what happens:
#define RATE 100
uint32_t start_time, end_time, delta_time;
  keys.begin();
  start_time = millis();
  keys.readGPIO();
  end_time = millis();
  delta_time = end_time - start_time;
  Serial.println(delta_time);
  delay(RATE);
by Keith_Henrickson on Tue Jul 25, 2017 12:57 am
Interesting....
With the M0 Datalogger, all 0s.
With the Wiced, I get:
2
2
2
3
2
2
2
2
2
Slightly more consistent than my code, but still much slower on the wiced than the datalogger.
Keith_Henrickson
by adafruit_support_carter on Sun Jul 30, 2017 12:15 pm
So basically you're curious why a 120MHz M3 reads slower than a 48MHz M0? Other than the timing difference, does it work as expected?
by Keith_Henrickson on Sun Jul 30, 2017 12:41 pm
The reason this is a problem is I am trying to scan a 4x4 keypad. It does work, in the sense that I get the right data back.
However, with every operation taking 2 ms, the rate of key scanning is miserable. Because a key scan isn't a single read of the i2c.
It actually makes my Chip 8 emulator run slowly, which says something given that it has a 2ms instruction time.
Keith_Henrickson
by adafruit_support_carter on Sun Jul 30, 2017 1:25 pm
Might be related to I2C speed. Use your scope and see what the I2C transaction looks like for the two different boards. That is, a scope trace for the M0 (Adalogger) and a scope trace for the M3 (Wiced). See if there is a difference in their frequency.
by Keith_Henrickson on Mon Oct 23, 2017 12:49 am
adafruit_support_carter wrote:Might be related to I2C speed. Use your scope and see what the I2C transaction looks like for the two different boards. That is, a scope trace for the M0 (Adalogger) and a scope trace for the M3 (Wiced). See if there is a difference in their frequency.
Sorry it took me so long to get back to this. Apparently one has time or money to work on hobbies, not both.
Anyway, the I2C clock on the WICED is just ever so slightly faster than the Datalogger. Not by enough that I'd think it matters. 9.96 us for the WICED, and 10.04 us for the Datalogger. That probably says more about my ability to measure than any actual difference in clock speed.
What's interesting is all reads end with the master sending a NACK bit. I thought this was occurring only on the WICED, but it seems to be occurring on the Datalogger as well (althogh the visible indications in software are everything works, just so slowly on the WICED that the keyscan doesn't work).
I'm wondering if this is layout related? There's some ringing going on on every falling edge. Is there any word on how much ringing I2C can tolerate? Or, is there any status register that can be read to see WHY the controller thinks a NACK was appropriate?
Keith_Henrickson
