Which library are you using?
The yellow on my screen looks like a vibrant yellow.
You can change the RGB value for Yellow if you want to make it brighter.
[SOLVED] Library ST7735 NEEDS SUPPORT for 1.54" 240x240 Wide
- solardude
- fazambuja
Re: Library ST7735 NOT WORKING for 1.54" 240x240 Wide Angle
I'm using the Adafruit graphictest file for now with:
I usually use the TFT_eSPI library using the really good looking smooth fonts and sprites to avoid flickering. What it's your setup?
Oh and I changed all the resolutions on the library to 240 x 240, just in case.
Testing the primaries, I found that the green is not saturated. Makes sense why the yellow is faded.
I will try other tables.
tft.initR(INITR_BLACKTAB);
tft.setRotation(2); // the one that works
tft.invertDisplay(1);
- solardude
I'm using the Particle Photon along with this library https://github.com/menan/adafruit_st7735
You can create custom fonts using this modified mfGFX library, which we got working years before the Adafruit added that feature to their GFX library. The mfGFX library uses a Windows program to create custom font arrays while the Adafrut font generator requires a Linux program to create new fonts I think.
I'm using the
I'm using the
Same as you are.tft.setRotation(2);
- fazambuja
That library looks good. I don't have a Particle Photon, I'm waiting for their new models :)
I noticed that they added the display for the Animated Snake Eyes Bonnet for Raspberry Pi (https://learn.adafruit.com/animated-sna ... spberry-pi). I might try to connect mine to a raspberry pi.
This how the green looks like against the not so vibrant M5Stack screen:
- Attachments
- IMG_0171.jpg (573.42 KiB) Viewed 1189 times
- solardude
Pull that protective sticker off the front of the screen for a better look.
Here are some more colors for you:
Have you figured out if the BL pin controls the backlight brightness yet? I have not tried.
The screen looks great and the resolution in this size is really good. I'm very happy with this screen.
#define LTBLUE 0xB6DF
#define LTTEAL 0xBF5F
#define LTGREEN 0xBFF7
#define LTCYAN 0xC7FF
#define LTRED 0xFD34
#define LTMAGENTA 0xFD5F
#define LTYELLOW 0xFFF8
#define LTORANGE 0xFE73
#define LTPINK 0xFDDF
#define LTPURPLE 0xCCFF
#define LTGREY 0xE71C
#define BLUE 0x001F
#define TEAL 0x0438
#define GREEN 0x07E0
#define CYAN 0x07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define ORANGE 0xFC00
#define PINK 0xF81F
#define PURPLE 0x8010
#define GREY 0xC618
#define WHITE 0xFFFF
#define BLACK 0x0000
#define DKBLUE 0x000D
#define DKTEAL 0x020C
#define DKGREEN 0x03E0
#define DKCYAN 0x03EF
#define DKRED 0x6000
#define DKMAGENTA 0x8008
#define DKYELLOW 0x8400
#define DKORANGE 0x8200
#define DKPINK 0x9009
#define DKPURPLE 0x4010
#define DKGREY 0x4A49
- fazambuja
Thanks, I will try later today.
I wish Adafruit at least acknowledge the issue, or tell us what are we doing wrong :(
I decided to try the github, hopefully, will get some response.
I also haven't tried the BL.
- fazambuja
Re: Library ST7735 NEEDS SUPPORT for 1.54" 240x240 Wide Angl
No luck with the color. It looks like green looks like 82FF9F http://www.color-hex.com/color/b5ffc6
- fazambuja
Re: [SOLVED] Library ST7735 NEEDS SUPPORT for 1.54" 240x240
Support is out!!!
However still not sure about the 3Vo and Backlight.
- adafruit2
hiya! sorry about that, we pushed the code to a branch and forgot to merge it with master >.<
we just did a release, check out v1.1.0 - you'll need to uncomment the ST7789 object but we just tested it! let us know how it goes
- solardude
Thanks for the updated library!adafruit2 wrote:hiya! sorry about that, we pushed the code to a branch and forgot to merge it with master >.<
Can you talk about the BL pin on this breakout? Does the brightness dim based on the PWM it receives?
When will the schematic for the PCB be uploaded?
- adafruit2
its like 99% identical to this:
https://learn.adafruit.com/adafruit-min ... /downloads
the backlight pin connects to a transistor, you can use it to PWM the backlight or turn it off.
- solardude
Thanks for the clarification!
I'll report back after testing the library changes.
- fazambuja
The graphicstest.ino works for me :)
Haven't tested the other ones yet.
- solardude
I can verify that the BL "BackLight" pin does work to dim the brightness of the screen.
I recorded these power draws when feeding the LCD 3.3v from a bench power supply.
0 PWM = 12mA - 0.039 watts @3.3v
50 PWM - 16mA - 0.052 watts @3.3v
100 PWM - 21mA - 0.069 watts @3.3v
150 PWM - 25mA - 0.082 watts @3.3v
200 PWM - 30mA - 0.099 watts @3.3v
250 PWM - 34-35mA - 0.112-0.115 watts @3.3v
- solardude
Can you tell me what the part number for the flex cable connector is on the 240x240 display PCB?adafruit2 wrote:its like 99% identical to this:
There is no schematic to reference.
Any help is appreciated.
