Hi all,
I am trying to get the "MPL3115A2 - I2C Barometric Pressure/Altitude/Temperature Sensor" running on my Arduino due. I connected the sensor to pins 20 and 21 (SDA and SCL) of the Due board and tried to run the example from the "Adafruit_MPL3115A2_Library" on GitHub.
However I can not get the connection to the sensor. When searcheing for the sensor with the I2C scanner, I get the information that there is a I2C device found at port 0x60 (which seems to be correct).
Has anyone made the same experinece with this product or have an idea how to solve this?
Thanks a lot!
MPL3115A2 can not be found
- adafruit_support_carter
Re: MPL3115A2 can not be found
Post a photo of your setup showing how you have everything connected.
- p_link
Attached is the foto of the setup that I have. It is very simple and wired as described in the GitHub example:
Vin to 5V, GND to GND
SCL to the SCL pin (21), SDA to SDA pin (20) of the Due
I already searched through the different threads here and found out that the Due obviously has some problems with the I2C wiring. Therefore I already tried the fixes, which are suggested here: viewtopic.php?f=19&t=73118&hilit=MPL3115A2&start=15
But for me this fix is unfortuantely not working.
Thanks in advance!
Thanks in advance!
- Attachments
- IMG_20181015_103846.jpg (475.4 KiB) Viewed 150 times
Do you have another Arduino board you can try? From that thread you linked:
Due is not recommended for anything, and especially not i2c :)
- p_link
No, I only have the Due and I didn't read the post beofre I bought the MPL3115A2.
- p_link
I have got it fixed so far, that the Example code at least can find the sensor and read the pressure values.
But now I have the problem, that I always get the same reading from the sensor. The pressure stays constant all the time. Do you know what could be the problem here?
- Attachments
- Pressure.PNG (40.98 KiB) Viewed 133 times
Do you get the same thing running the unmodified example sketch?
https://github.com/adafruit/Adafruit_MP ... 3115a2.ino
- p_link
Yes, I get the same behavior. Also the Temperature measurement is constant at a value of -0.06°C, which can not be right, of course.
- Attachments
- Serial_Monitor.PNG (33.88 KiB) Viewed 123 times
I think you're still having the basic issue of dealing with unreliable I2C comms on the Due.
