For my past project, I soldered GPIO and I2C lines for other sensors directly to the Motor Hat.
For my current project, I'd like to avoid doing that. Can you suggest a combination of connectors, such as headers or perma-proto, that would help me avoid soldering other lines direct to my Motor Hat? The goal is to keep the Motor Hat "clean" so I can re-use it another project in the future if necessary.
Avoiding soldering directly to Motor Hat
- adafruit_support_bill
Re: Avoiding soldering directly to Motor Hat
There is a row of GPIO breakout holes next to the GPIO header. You could solder a strip of female header there and plug any connections into the header.
- robreuss
Thanks.
In order to avoid soldering to the Motor Hat at all (other than the header) could I use the extra long 2x20 header for the Motor Hat and then do the additional attachments using the Perma-Proto HAT (#2310)? Not sure exactly how these connections work.
Yes. You could build the perma-proto HAT withone of the stacking headers, then connect your other hardware using the GPIO breakout holes on the Perma-Proto.
https://www.adafruit.com/product/1979
https://www.adafruit.com/product/2223
https://www.adafruit.com/product/2310
- robreuss
Great!
The Perma-Proto (#2310) says that pin #26 is not available. Is that hardware pin #26 (SPIO CS1) or GPIO 26?
That would be GPIO #26. Although, if you build both HATs with stacking headers, you can get at it that way as well.
- robreuss
It was the SPI pin that I needed, so that's perfect.
Thanks for your quick responses.
- robreuss
Should I use stand-offs with the extra tall, extra long header (https://www.adafruit.com/product/1979)? The 16mm?
If you have a Pi model B+, you need the extra tall ones to clear the Ethernet & USB jacks. They will also work with other models of the Pi.
