VL53L0X Time of Flight Distance Sensor
Re: VL53L0X Time of Flight Distance Sensor
by adafruit_support_carter on Wed Apr 25, 2018 10:38 am
lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
what does false do here?
It's a debug flag:
https://github.com/adafruit/Adafruit_VL ... 3L0X.h#L48
if (measure.RangeStatus != 4) { // phase failures have incorrect data
why does it have to be != 4?
It's checking to make sure there is no phase failure on the measurement, which would be a value of 4.
https://github.com/adafruit/Adafruit_VL ... s.cpp#L224
https://github.com/adafruit/Adafruit_VL ... ngs.h#L201
by AlexSneedMiller on Fri Jun 14, 2019 2:48 pm
Are there other docs for this board that give a high level overview of best practices for ranging, calibrating, checking for errors, etc? Or does everyone just manually go through the library and check the datasheet (https://www.st.com/resource/en/datasheet/vl53l0x.pdf)?
AlexSneedMiller
by adafruit2 on Fri Jun 14, 2019 3:23 pm
all we have are the docs ST provides !
adafruit2
Site Admin
