This is an example for the Adafruit VS1053 Codec Breakout
Designed specifically to work with the Adafruit VS1053 Codec Breakout
----> https://www.adafruit.com/products/1381
products from Adafruit!
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// These are the pins used for the breakout example
#define BREAKOUT_RESET 9 // VS1053 reset pin (output)
#define BREAKOUT_CS 10 // VS1053 chip select pin (output)
#define BREAKOUT_DCS 8 // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET -1 // VS1053 reset pin (unused!)
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4 // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
// create breakout-example object!
//Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
// create shield-example object!
Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
Serial.println("Adafruit VS1053 Library Test");
// initialise the music player
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
Serial.println(F("VS1053 found"));
musicPlayer.sineTest(0x44, 500); // Make a tone to indicate VS1053 is working
if (!SD.begin(CARDCS)) {
Serial.println(F("SD failed, or not present"));
while (1); // don't do anything more
Serial.println("SD OK!");
// list files
printDirectory(SD.open("/"), 0);
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(20,20);
/***** Two interrupt options! *******/
// This option uses timer0, this means timer1 & t2 are not required
// (so you can use 'em for Servos, etc) BUT millis() can lose time
// since we're hitchhiking on top of the millis() tracker
//musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT);
// This option uses a pin interrupt. No timers required! But DREQ
// must be on an interrupt pin. For Uno/Duemilanove/Diecimilla
// that's Digital #2 or #3
// See http://arduino.cc/en/Reference/attachInterrupt for other pins
// *** This method is preferred
if (! musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT))
Serial.println(F("DREQ pin is not an interrupt pin"));
// Alternately, we can just play an entire file at once
// This doesn't happen in the background, instead, the entire
// file is played and the program will continue when it's done!
musicPlayer.playFullFile("track001.ogg");
// Start playing a file, then we can do stuff while waiting for it to finish
if (! musicPlayer.startPlayingFile("/TRACK001")) {
Serial.println("Could not open file TRACK001");
while (1);
Serial.println(F("Started playing"));
while (musicPlayer.playingMusic) {
// file is now playing in the 'background' so now's a good time
// to do something else like handling LEDs or buttons :)
Serial.print(".");
delay(1000);
Serial.println("Done playing music");
/// File listing helper
void printDirectory(File dir, int numTabs) {
while(true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
//Serial.println("**nomorefiles**");
break;
for (uint8_t i=0; i<numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs+1);
} else {
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
Adafruit VS1053 Simple Test
VS1053 found
TRACK0~1.MP3 14005206
Playing track 001
Playing track 002
Done playing music
Playing track 001
Playing track 002
VS1053 found
VS1053 found
SD OK!
TRACK001.MP3 14005206
