Music Maker MP3 Shield
Re: Music Maker MP3 Shield
by adafruit2 on Tue Jun 25, 2019 8:24 pm
rename the files to "TRACK1.MP3" and "TRACK2.MP3" and make the sketch match
adafruit2
Site Admin
by garyallen on Tue Jun 25, 2019 9:05 pm
OK. Simple sketch results:
Adafruit VS1053 Simple Test
VS1053 found
TRACK1~1.MP3 14005206
TRACK2~1.MP3 14005206
Playing track 001
Playing track 002
Done playing music
And Interrupts sketch results:
Adafruit VS1053 Library Test
VS1053 found
SD OK!
Could not open file TRACK1.MP3
garyallen
by adafruit2 on Tue Jun 25, 2019 9:21 pm
the files it sees are
"TRACK1~1.MP3 14005206
TRACK2~1.MP3 14005206"
which means you did not rename them properly. please post a screenshot showing the files on the SD card
adafruit2
Site Admin
by garyallen on Wed Jun 26, 2019 1:28 am
Here is a screen shot of the SDcard files
garyallen
by adafruit2 on Wed Jun 26, 2019 1:54 am
perform this to enable showing extensions in case they are not
https://www.thewindowsclub.com/show-fil ... in-windows
adafruit2
Site Admin
by garyallen on Wed Jun 26, 2019 12:08 pm
ok
garyallen
by adafruit2 on Wed Jun 26, 2019 12:18 pm
and post another screenshot
also right click on the MP3s to "Properties" and screenshot that
adafruit2
Site Admin
by garyallen on Wed Jun 26, 2019 12:38 pm
Here's screen shot with extensions:
Here's the properties screen shot:
garyallen
by adafruit2 on Wed Jun 26, 2019 12:40 pm
k do you see the issue :)
adafruit2
Site Admin
by garyallen on Wed Jun 26, 2019 12:53 pm
I wish I could say that the problem is obvious but I'm not seeing it. Sorry.
garyallen
by adafruit2 on Wed Jun 26, 2019 12:55 pm
your files are called "Track1.mp3.mp3" not "track1.mp3"
adafruit2
Site Admin
by adafruit_support_carter on Wed Jun 26, 2019 12:58 pm
Your files are named TRACK1.MP3.mp3. Windows added and hid the .mp3 extension making the files look like they were named TRACK1.MP3. They are not. This was also non-obvious in the serial console output due to the truncation to the 8.3 format. But the appearance of the ~ in the name was a major clue.
Rename them by removing the extra .mp3.
by garyallen on Wed Jun 26, 2019 1:03 pm
Wow. Thank you for revealing this to me. My ignorance is on full display but I am accustomed to that. Can't work on it now. But I'll let you know if the problem is solved. Thanks again.
garyallen
by garyallen on Wed Jun 26, 2019 4:49 pm
It works! Thank you. Now if I can just incorporate some servos and leds into my project. Baby steps.
garyallen
by edwardanoliefo on Thu Aug 22, 2019 4:47 am
My own shield is not seen by the microcontroller. What do I do
edwardanoliefo
