Can't read INA219 right with Raspberry Pi and i2cget
by njsss on Fri Sep 13, 2019 4:22 pm
I have a simple setup with a LED and resistor pair just for testing. Both multimeter and python code (with pi-ina219 1.2.0) read the correct value of about 3.3mA.
But when I try to use i2c-tools I couldn't get it right. Here's what I did:
1) I set the CALIBRATION to 16V_400mA with 0x2000
i2cset -y 1 0x40 0x05 0x20 0x00 i  // 8192
2) I then copied the configuration from Adafruit_INA219 lib
INA219_CONFIG_BVOLTAGERANGE_16V = (0x0000), // 0-16V Range
INA219_CONFIG_GAIN_1_40MV = (0x0000),  // Gain 1, 40mV Range
INA219_CONFIG_BADCRES_12BIT = (0x0180), // 12-bit bus res = 0..4097
INA219_CONFIG_SADCRES_12BIT_1S_532US = (0x0018), // 1 x 12-bit shunt sample
INA219_CONFIG_MODE_SANDBVOLT_CONTINUOUS = 0x0007
this gives me the configeration after "OR": 0x019F
i2cset -y 1 0x40 0x00 0x01 0x9f i
3) I tried to read the current
i2cset -y 1 0x40 0x04 w
This gives me either 0x4400 or 0x4200, which if divided by 20 (ina219_currentDivider_mA = 20) is 8704?
Can someone help me get it right?
njsss
Re: Can't read INA219 right with Raspberry Pi and i2cget
by mikeysklar on Mon Sep 16, 2019 8:03 pm
Hello njsss,
When this worked for you where you using our CircuitPython adafruit-blinka and adafruit-circuitpython-ina219 libraries on your Pi?
https://learn.adafruit.com/adafruit-ina ... cuitpython
mikeysklar
by njsss on Tue Sep 17, 2019 6:10 pm
mikeysklar wrote:Hello njsss,
No, I did not. I used the pi-ina219 instead (https://pypi.org/project/pi-ina219/). My goal is to use the sensor with c++, so I used python to verify if the value was right.
njsss
by mikeysklar on Tue Sep 17, 2019 6:29 pm
Gotcha...that C++ code is a little outside our scope, but if you have any issue with our CircuitPython demo I will be happy to assist you.
mikeysklar
