Change I2C address of 2nd ADXL 345
by AnkV4 on Wed Sep 18, 2019 3:03 am
I am working on project that requires two ADXL 345 accelerometers to sample simultaneously on a Raspberry pi 3. I am using the Adafruit ADXL 345 python library: https://github.com/adafruit/Adafruit_Python_ADXL345.
My setup is running fine with one ADXL 345 at I2C address 0x53. Requesting for guidance on how (and where) may I change the I2C address for interfacing the 2nd ADXL 345 simultaneously with the first one.
Thanks in advance for any help !!
AnkV4
Re: Change I2C address of 2nd ADXL 345
by franklin97355 on Wed Sep 18, 2019 3:52 am
With the ALT ADDRESS pin
high, the 7-bit I2C address for the device is 0x1D, followed by
the R/W bit. This translates to 0x3A for a write and 0x3B for a
read. An alternate I2C address of 0x53 (followed by the R/W bit)
can be chosen by grounding the ALT ADDRESS pin (Pin 12).
This translates to 0xA6 for a write and 0xA7 for a read.
Pin 12 is the pin marked SDO on the board.
franklin97355
by AnkV4 on Thu Sep 19, 2019 7:43 am
Hi franklin97355,
Firstly, thank you for your reply !
I would like to say the following two points:
1. By setting the SDO pin low and high, I am able to detect I2C addresses 0x53 and 0x1d respectively. This works fine now.
2. As per my understanding, now I need to change the read address from 0xa7 to 0x3b to switch from address 0x53 to 0x1d? Could you please guide me to the file where I need to make this change?
I have searched my local files; there is none where read and write bit is being set. I tried running 'simpletest.py' with modified address to 0x1d:
accel = Adafruit_ADXL345.ADXL345(address=0x1d, busnum=1)
but the following error occurs (because I have not changed the read bit address (as per my understanding)).
pi@pi:~/Adafruit_Python_ADXL345/examples $ python simpletest.py
  File "simpletest.py", line 12, in <module>
    accel = Adafruit_ADXL345.ADXL345()
  File "build/bdist.linux-armv7l/egg/Adafruit_ADXL345/ADXL345.py", line 65, in __init__
  File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/I2C.py", line 150, in readU8
  File "build/bdist.linux-armv7l/egg/Adafruit_PureIO/smbus.py", line 169, in read_byte_data
IOError: [Errno 121] Remote I/O error
Thanking you.
AnkV4
