Submersible 3V DC Water Pump Quit?
mnopneal
Post by mnopneal »
Submersible 3V DC Water Pump - Vertical Type[ID:4547] was purchased Order Confirmation No: 2532533-9057995396.
It has trended towards intermittent, and now appears to not run at all.
Voltage at the terminal at the buckaroo board is 3.29V.
Picture shows a slight rust stain, which makes me suspect the seal has failed.
Thoughts?
Franklin97355
Re: Submersible 3V DC Water Pump Quit?
Post by Franklin97355 »
Make sure you don't run this pump dry as this can damage it. Contact [email protected] with a link to this thread and they will get you a new one. Thanks for the picture.
