SHT-10 Mesh-protected Weather-proof Temperature/Humidity Sen
by NeelC on Tue Jul 27, 2021 1:57 pm
What is the output of this device is is volts,amps,etc? and what do I do with the clock pin/wire if my setup doesn't directly account for such a wire/pin? do I just treat the data and clock wire as one and use the 2 as a single output?
SENSOR PICTURE.png (776.13 KiB) Viewed 34 times
NeelC
Re: SHT-10 Mesh-protected Weather-proof Temperature/Humidity
by adafruit_support_bill on Tue Jul 27, 2021 2:18 pm
The device has a digital interface using the Sensirion SHT-1x protocol.
Connect:
* Black -> GND.
* Red -> VCC (3.3v-5v depending on your processor)
* Yellow -> Clock Pin
* Green -> Data Pin.
There is a library that implements the communication protocol here: https://github.com/practicalarduino/SHT1x
Clock and Data pins are specified in the constructor when you declare the object in your code.
