Another LIS3MDL failure
by w5hvs on Fri Jul 30, 2021 2:15 am
I have just the basic setup for the LIS3MDL board... just the board connected to an Arduino Nano using IC2 communications. Problem is the Adafruit's "lis3mdl_demo" sketch keeps failing with the message "Failed to find LIS3MDL chip". Also, when I ran Arduino’s “IC2_Scanner” sketch the address reported was “0x1E”. I had Amazon replace the board and the same error occurs.
Looking through the forum, the last reference to this error was by ‘adafruit2’ on ‘Sat Mar 12, 2005 12:36 am’ under the post “LIS3MDL begin_I2C failure”.
I will add the following info to this problem: With the replacement board powered up, I first ran the Arduino “IC2_Scanner” sketch with the resulting address to be "0x1C". Load and run the “lis3mdl_demo” sketch and get “failure” msg. Load and run “I2C_Scanner” sketch and now the address comes back as “0x1E”! Disconnect power from Nano, power back up, load and run “IC2_Scanner” sketch and the address is “0x1C” again. Run “lis3mdl_demo” sketch, get error msg, load and run scanner sketch and the address changed to “0x1E’!!! FYI... running Adafruit_LIS3MDL library, v 1.10... Something is not working correctly…. Please advise… thank you.
w5hvs
Re: Another LIS3MDL failure
by adafruit_support_bill on Fri Jul 30, 2021 5:40 am
Please post some photos showing all of your soldering and connections.
by w5hvs on Fri Jul 30, 2021 2:08 pm
As requested, photos attached...
w5hvs
by adafruit_support_bill on Fri Jul 30, 2021 2:35 pm
Try connecting the DO pin to GND.
by w5hvs on Tue Aug 03, 2021 7:25 pm
Success! That fixed the problem! Hopefully you will update your website so that future “first timers” will not have to go thru the frustrations of “sketch errors”! Again, thank you for your help!
w5hvs
