adafruit ina260 Vbus is too high
by Tooot on Sun Sep 19, 2021 6:00 am
Hello guys, I use my stm32 F4 board to connect with adafruit ina 260, but Vbus is so high, i have no idea why.
get voltage:10984
get current: 148
get power:: 560
this is also without load, still Vbus is so high, is this module broken?
Tooot
Re: adafruit ina260 Vbus is too high
by adafruit_support_bill on Sun Sep 19, 2021 6:58 am
Your photo does not show all of your connections. Also please post the code you are using.
by Tooot on Sun Sep 19, 2021 7:50 am
i'm sorry , this is the whole circuit, i measured the Vbus always 11v. i dont understand where this comes from......
Thank you!
Core.zip
(25.15 KiB) Not downloaded yet
Tooot
by adafruit_support_bill on Sun Sep 19, 2021 8:07 am
I don't see a ground connection between the INA260 and the circuit under test. Voltage is measured relative to ground. So without a ground connection to the circuit under test, the voltage readings are meaningless.
by Tooot on Sun Sep 19, 2021 9:10 am
the white cabel with read red "G", that is ground. also you can see it from 2.png
Tooot
by adafruit_support_bill on Sun Sep 19, 2021 9:38 am
That is the ground from your processor to the INA260. The voltage you are trying to measure is on the red board and you do not have a ground connection to it.
by Tooot on Sun Sep 19, 2021 11:11 am
thank you so much for help, i did it!!! thank you again!
Tooot
by adafruit_support_bill on Sun Sep 19, 2021 11:55 am
Good to hear. Thanks for the follow-up.
