Bad Hollowing Screen from Adabox009
by Flashno13 on Fri Sep 24, 2021 10:43 am
Hollowing M0 Express Bad Display
AdaWing 800 600 20210923_161442.jpg (67.08 KiB) Viewed 71 times
adawing board 800 600 20210923_161605.jpg (46.55 KiB) Viewed 71 times
This is my 2nd try at posting a replacement message of my Hollowing M0 Express Product:3900 in my Adabox009. The forum would not accept my photos even though they are 800 x 600. I received this Adabox as a recent gift. The giver has misplaced/lost all info of the purchase. But opening the box yesterday and trying out the Hollowing by plugging in the included battery, the screen was blacked out in the far left bottom corner. The eyeball program runs fine, it is just the display that is faulty. I need a replacement of either the Hollowing or the display. I want to make a Holloween Skull using this key component of the box, so I hope that you can send soon. I see that you have a supply of these. I don't know if you have the tft displays. When the screen fires up, it displays Digikey logo briefly. If the files are not accepted for the 2nd time, I need a way to send via email because I know that works perfectly.
Gary K
Flashno13
Re: Bad Hollowing Screen from Adabox009
by adafruit_support_carter on Fri Sep 24, 2021 12:41 pm
Can you try running this test sketch and post a photo of what the screen looks like running that:
https://learn.adafruit.com/adafruit-hal ... est-sketch
You don't need to install Arduino. You can download the hallowingtest.UF2 file linked at the bottom of the page. Then double press reset on the Hallowing to get the BOOT folder to show up on your PC and then drag the downloaded UF2 file to that folder. Once copied, it should reset and then run the sketch.
by Flashno13 on Fri Sep 24, 2021 1:41 pm
Totally not the problem. The sketch runs great. The screen has many bad pixels. Take a closer look and you can see the dead screen in the lower left corner.
I need a replacement screen or hallowing. Please send.
Gary K
Flashno13
by adafruit_support_carter on Fri Sep 24, 2021 1:53 pm
It's hard to make out the issue in the photo above with the eyeball. Can you post another showing the screen running the self test UF2.
by Flashno13 on Fri Sep 24, 2021 2:06 pm
Your system barely handles 800x600. I am very doubtful it can handle a mpeg. It was frustrating enough to get a 800x600 file to work on your forum. I spent over an hour to get your system to upload! The eyeball moves freely around the screen as it was designed, but it is completely obvious that the left corner is totally blacked out by dead pixels. The only solution is to replace the TFT or Hallowing. Please send.
Gary K
Flashno13
by Flashno13 on Fri Sep 24, 2021 2:47 pm
Dead Screen
800 x 600 Dead Screen 20210924_143821.jpg (61.42 KiB) Viewed 58 times
I can only hope and pray that this distorted 800 x 600 jpg will upload. This should make it very obvious that this is a screen problem. Please send a replacement.
Gary K
Flashno13
by adafruit_support_carter on Fri Sep 24, 2021 5:06 pm
OK, yep, can see it now.
AdaBox 009 is about 3 years old at this point. What has the hardware been doing for the last 3 years?
by Flashno13 on Sat Sep 25, 2021 10:19 am
I just opened a sealed Adabox009 box that I recently received as a gift. Everything in the box is pristine new condition including the box that it came in. The individual components were either wrapped in bubble wrap, sealed in packages, or in their marked boxes. Even the screen protector was still on the Hallowing. So to suggest that this was "used" equipment is unfounded. I see that you currently sell this Hollowing M0 Express, would I be remiss in concluding that these components are "used" because these were built 3 years ago? I think we can both agree that the only fact is that these were built 3 years ago. To think that these were used would be factually wrong and it would be starting a conspiracy that would be unfounded. I ask others to weigh in on this forum if they feel that I am right about this. So I ask again, please send me either a replacement screen or Hallowing so I can complete my Holloween project.
Flashno13
by adafruit2 on Sat Sep 25, 2021 1:55 pm
hi, normally our replacement window is 30 days. for this one time, we can replace the hallowing, please check that everything else is there.
adafruit2
Site Admin
by Flashno13 on Mon Sep 27, 2021 9:41 am
I did a inventory of all the items in the box and it is complete. When can I expect the replacement?
Gary K
Flashno13
by adafruit2 on Mon Sep 27, 2021 10:08 am
you can email support@adafruit with a link to this thread
adafruit2
Site Admin
