Received Audio FX board with headphone jack. I have not been able to play any .wav or Ogg files. I can see the files such as T00.wav but it will not play when pin 0 is grounded. From my research when a pin is triggered I should see a red led flash, I do NOT. I have tried various files from the support site and labeled them according to the proper nomenclature and different pin ports with the same results.
Could this board be bad?
Audio FX not playing sound file
- toms73novass
Re: Audio FX not playing sound file
Also wanted to add. The board was not plugged into the computer when I was testing to play sounds.
- adafruit_support_carter
Are you testing with the wav files from the Demo_Tracks.zip downloaded from here?
https://learn.adafruit.com/adafruit-aud ... udio-files
- toms73novass
Ok, with those files it works!
I did not realize if you have one file that does not meet the specifications, NONE work!
