Defective Raspberry Pi 4
by ronaldlw on Tue Sep 28, 2021 10:18 am
I purchased several pis and one of them is not working correctly. What do i need to do to get a replacement?
ronaldlw
Re: Defective Raspberry Pi 4
by adafruit_support_carter on Tue Sep 28, 2021 12:49 pm
Did you purchase all the same model Pi's?
What exact version of Pi 4 is the one not working?
What are you using to power the Pi?
What OS image are you using and how did you image it to the SD card?
Can you provide more info on what is not working? Not booting? Not displaying on screen? GPIO pins aren't working? Something else?
by ronaldlw on Tue Sep 28, 2021 1:12 pm
I purchased a 4gb and 8gb pi at the same time along with the power supplies:
https://www.adafruit.com/product/4298
https://www.adafruit.com/product/4296
https://www.adafruit.com/product/4564
I'm using pikvm currently. The 8GB pi is fine, but the 4gb pi will lock up after about an hour of being turned on.
I use winimage to write the image typically.
Sometimes the pi won't boot, sometimes it will. when it does sometimes it boots up all the way, sometimes is freezes before completely booting up. When it does boot up it usually freezes after about an hour. I've tried swapping the sd cards between the two and the issue stays with the 4gb pi
adafruit_support_carter wrote:Did you purchase all the same model Pi's?
ronaldlw
by adafruit_support_carter on Tue Sep 28, 2021 1:14 pm
Thanks for the info. That all looks fine. For the sake of troubleshooting, please try imaging Raspberry Pi OS Lite and run that on the problematic Pi. See if you get the same general behavior with that OS image.
by ronaldlw on Tue Sep 28, 2021 11:53 pm
Why would i need to do that? I can literally move the sd card from one pi4 to another and it works fine.
ronaldlw
by adafruit_support_carter on Wed Sep 29, 2021 12:24 pm
Because we are troubleshooting.
by ronaldlw on Wed Sep 29, 2021 6:17 pm
I can't hardly even get it to display a boot screen with that image. Again, i can put the same card in a different pi and it boots up fine. but in this one most of the time it won't even show anything on the screen and the green led just flashes quickly. if i pull out the card i get a screen saying it can't read the sd card.
ronaldlw
by ronaldlw on Thu Sep 30, 2021 11:30 am
After rebooting and messing around with it for over an hour it finally booted up, but when i looked at it again this morning it had locked up and I can't get it to boot again.
ronaldlw
by adafruit_support_carter on Thu Sep 30, 2021 12:01 pm
OK, thanks for double checking with Raspberry Pi OS. Let's replace it.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement 4G Pi (PID 4296).
by ronaldlw on Thu Sep 30, 2021 12:45 pm
Thanks, will do
ronaldlw
