MLX90640 bad output on FeatherS2 but good output on QtPy
by rrace001 on Wed Oct 13, 2021 4:19 pm
Trying to run Arduino MLX90640_simpletest on FeatherS2 via Stemma cable. The FeatherS2 recognizes the MLX90640 and outputs the ascii matrix but only the lowest readings (all &). The MLX90640 runs on my QtPy . That is my likeness in the output! I know the FeatherS2 is not your board but hoping someone could point me in the right direction. I noticed the serial is not the same between the outputs and neither are the resolution and rate. Ran it with the float output and every other line is nan.
QtPy:
Adafruit MLX90640 Simple Test
Found Adafruit MLX90640
Serial number: 928F924189
Current mode: Chess
Current resolution: 18 bit
Current frame rate: 2 Hz
x+******************************
x+*********++*******************
x+***********+******************
+********++++x+++***************
+*******++xx%xxx++**************
+*******++x%%%xx+***************
+*******++%#%#%x+***************
********+x%%%xxx+***************
*******++x%%#%%%+***************
*******++x#####%+***************
********+x######+***************
********+x%%%%%%+***************
********+x%%x%%%+***************
****++xx%%##%%%%+++*************
***+xxx%%%##%#%%xx+x************
**+x%%%%%%######%%%xxx+*********
++xx%%%%%%%#####%%%%xx++********
xx%%%%%%%%%%%%%%%%%%%%xx++****++
xx%%%%%%%%%%%%%%%%%%%%%%xx++++++
FeatherS2:
Outlier pixels: 5
Serial number: 8BE899F
Current mode: Interleave
Current resolution: 16 bitQt
Current frame rate: 0.5 Hz
rrace001
Re: MLX90640 bad output on FeatherS2 but good output on QtPy
by adafruit_support_carter on Wed Oct 13, 2021 5:32 pm
What version of the ESP32 Arduino BSP are you using?
by rrace001 on Wed Oct 13, 2021 6:59 pm
esp32 by Espressif Systems version 2.0.0 on Arduino 1.8.15.
rrace001
by adafruit_support_carter on Wed Oct 13, 2021 7:28 pm
Try reverting to the 1.0.6 release of the ESP32 BSP.
by rrace001 on Wed Oct 13, 2021 9:15 pm
Unfortunately the FeatherS2 is not included in the previous versions. I just tried the Sharp memory display (SPI) and it too does not work on the Feather S2 but does on the QtPy. I did get the FeatherS2 to host a web page so not a complete failure. Anyway, thanks for responding. I will write to UM to see what they say.
rrace001
by adafruit_support_carter on Thu Oct 14, 2021 11:17 am
Thanks. That's probably best. This is most likely an issue with the ESP32 BSP. Not UM's responsibility, but working directly with them will be more efficient.
