Smallest Arduino alternative
by nessimdave on Thu Oct 21, 2021 7:08 pm
hi all
I have a circuit that uses an FSR and an RGB LED , I have my code so that as the force is applied to the FSR the RGB goes from blue (no force ) then Green , then red (max force)
My question is what is the smallest Microprocess availble that i can replace my Ardunio board?
is there a simpler way to achieve this ?
Here is an example of my schemetic, but I am only using one FSR
/* Pressure sensitive test
const int fsrAnalogPin1 = 0; // connect FSR 1 to analog 1
const int RED_PIN = 2; // connect the red pin to pin 2
const int GREEN_PIN = 3; // connect the green pin to pin 3
const int BLUE_PIN = 4; // connect the blue pin to pin 4
int fsrReading1; // the analog reading from FSR 1 resistor divider
  Serial.begin(9600);   // set the speed of the serial monitor
  pinMode(RED_PIN, OUTPUT); // set the output of the red pin
  pinMode(GREEN_PIN, OUTPUT); // set the output of the green pin
  pinMode(BLUE_PIN, OUTPUT); // set the output of the blue pin
  fsrReading1 = analogRead(fsrAnalogPin1); // read the value of FSR 1
  Serial.print("FSR1 = "); Serial.println(fsrReading1); // print the value of FSR 1 on serial monitor
  if ((fsrReading1<100))
    digitalWrite(RED_PIN, LOW);
    digitalWrite(GREEN_PIN, LOW);
    digitalWrite(BLUE_PIN, HIGH);
    // the blue light turns on with very little pressure
   else if ((fsrReading1>100) && ( fsrReading1 < 150))
    digitalWrite(GREEN_PIN, HIGH);
    digitalWrite(BLUE_PIN, LOW);
    // the green light turns on when are at the correct pressure for probe
   else if ((fsrReading1>150))
    digitalWrite(RED_PIN, HIGH);
    // the RGB will turn on red light
  delay(2000); // loop the code for each 2 seconds
nessimdave
Re: Smallest Arduino alternative
by westfw on Thu Oct 21, 2021 9:28 pm
Do you need the Serial connection? Or is that just for debugging? (it's two more pins...)
What about actual USB connectivity (vs perhaps using an external USB/Serial converter for uploads or debugging)?
And ... 5V vs 3.3V IO?
The Adafruit QT Py is pretty tiny.
westfw
by nessimdave on Fri Oct 22, 2021 5:50 am
hi
thanks for the reply,, I don't need the serial ,that was for debugging. what options do i have if i don't actually need the USB, if there is another way to upload you mentioned?
I have tested my FSR and the RGB led using the 3 volt so that that seems to be Ok.
nessimdave
