is it possible to purchase pre-programmed SAMD09 boards identical to the ones built into the "NeoKey 1x4 QT I2C" board ?
If yes, what is the price, delivery-time and how do I order ?
If no, is it possible to at least get the source-code of the SMAD09 microcontroller identical to as built into the "NeoKey 1x4 QT I2C" board ?
Thank you for any help on this.
SAMD09 pre-programmed purchase
- dastels
Re: SAMD09 pre-programmed purchase
The code is on github: https://github.com/adafruit/Adafruit_Seesaw
You will need a jlink thingy to program the SAM9 though, e.g. https://www.adafruit.com/product/3571
- skuenstler
Thank you Dave, which one is the SAMD09 code exactly. I only find lots of Arduino-IDE .cpp files. But which one is the SAMD09 microcontroller code that I can then burn via the J-Link ?
Thanks for a clarification.
- skuenstler
I finally found the correct link:
https://github.com/adafruit/seesaw
Here I find the SAMD09 microcontroller Software for the several seesaw boards...
