90640 IR camera
90640 IR camera
by alainsam on Thu Nov 18, 2021 4:31 pm
I just bought this IR camera and trying to test it with the example on arduino IDE: MLX90640_simpletest
I use the Feather HUZZAH with ESP8266 With Headers and connect the sensor with I2C with STEMMA
The sketch seems to compile without problem but there is no output on the serial monitor,it seems that the serial output is "frozen"
Any idea?
Attached File: Compiler output
90640simpleOutput.txt
(63.11 KiB) Downloaded 5 times
alainsam
Re: 90640 IR camera
by adafruit_support_carter on Thu Nov 18, 2021 5:36 pm
You don't even see
Adafruit MLX90640 Simple Test
printed in the serial monitor?
That's the first thing that gets printed and doesn't require anything special from the MLX:
https://github.com/adafruit/Adafruit_ML ... st.ino#L15
Re: 90640 IR camera
by alainsam on Thu Nov 18, 2021 10:07 pm
Nope - Nothing!...
alainsam
Re: 90640 IR camera
by sj_remington on Thu Nov 18, 2021 10:37 pm
Check the serial monitor baud rate. It should match the Serial.begin() baud rate.
sj_remington
Re: 90640 IR camera
by alainsam on Fri Nov 19, 2021 3:58 am
Yes, that was the first thing I did, I also changed the USB cable and verified all connections to the camera. I also tested the output with the basic examples: Blink and ASCII tables display on the monitor. All worked fine...
alainsam
Re: 90640 IR camera
by sj_remington on Fri Nov 19, 2021 12:10 pm
Disconnect the sensor completely and run the program again. If it doesn't print, the problem is not in the sensor.
Printing is the first thing the program does, and that is independent of sensor presence.
  while (!Serial) delay(10);
  Serial.begin(115200);
  delay(100);
  Serial.println("Adafruit MLX90640 Simple Test");
sj_remington
Re: 90640 IR camera
by adafruit_support_carter on Fri Nov 19, 2021 12:52 pm
Yah, if you aren't seeing that first print in the Serial Monitor, then something else is happening. Try and figure out why you can't see the serial prints. It sounds like it's at least working for other examples?
Re: 90640 IR camera
by alainsam on Fri Nov 19, 2021 5:14 pm
I disconnected the camera resulting also in no output on the monitor after running the program.
Attached is the Tool settings
One thing I remarked when trying to upload the 90640 library for update: It asks for a long list of dependencies: There is none of them in my library folder and I don't see the use of these. Can you comment?
alainsam
Re: 90640 IR camera
by adafruit_support_carter on Fri Nov 19, 2021 5:52 pm
If you install via Library Manager, it should take care of installing the dependencies.
If you are missing any necessary dependency, then you shouldn't even be able to compile the example. But you mention it compiles OK in your first post. So it seems like you have the required libraries. The dependencies can chain and thus the resulting list of everything (your photo) can be long. Those are the libraries needed for *everything* in the MLX90640 library, including all example sketches.
Re: 90640 IR camera
by alainsam on Fri Nov 19, 2021 8:35 pm
Ah! I now have the following printed on the monitor:
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v00043350
~ld
I think that some error from the ESP- I am not familiar with that not being ESP savy What should I do to correct it?
alainsam
Re: 90640 IR camera
by alainsam on Fri Nov 26, 2021 6:38 pm
Can somebody help me with this? I am really stuck...
alainsam
Re: 90640 IR camera
by adafruit_support_carter on Mon Nov 29, 2021 2:46 pm
Backup and verify that you can at least successfully upload the basic Blink example:
https://learn.adafruit.com/adafruit-fea ... 2720758-28
Re: 90640 IR camera
by alainsam on Tue Nov 30, 2021 12:59 am
Yes the BLINK test works...
I have an AMG88xx: I am able to load the test but when it is running, nothing shows on the Monitor like for the 90640 IR..I really think that my Feather8266 has a defect. Can I have an RMA for it can not be fixed?
alainsam
Re: 90640 IR camera
by adafruit_support_carter on Tue Nov 30, 2021 12:38 pm
If you can load and run a blink example, then the board is generally OK.
Please post a photo showing how you are connecting the IR camera to the Feather.
Re: 90640 IR camera
by alainsam on Wed Dec 01, 2021 5:47 pm
Can't post the setting of the 90640 now as I am using it within a closed box with an ESP32 All the connections and software are the same, except for ESP32, and it works... So I definitively think that the ESP8266 has a problem.
Here is the photo with the sketch test for AMG88xx plugged into the ESP8266 I have the same problem: No output on the monitor...
alainsam
