Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days. On MLK Day no orders will be shipped.
[Defect] Sharp 2.7 inch memory LCD
by kw81634dr on Fri Nov 19, 2021 2:25 am
I bought a [Sharp 2.7” memory LCD] last week, got it yesterday.
The screen doesn't work until I gently press down on the FPC part of the module.
The symptom seems FPC doesn't contact well to LCD.
Since it's a product defect, is it possible to get a replacement?
Attached are photos demonstrating the symptom, the image faded out right after I stopped pressing the FPC.
( I attempt to attach a short video clip that is intuitive, but your forum system doesn't allow me to do so.)
Thank you.
Kevin
1. FPC pressed.
截圖 2021-11-18 下午10.14.46.png (394.52 KiB) Viewed 337 times
2. Release FPC, image start fading out.
截圖 2021-11-18 下午10.15.15.png (384.67 KiB) Viewed 337 times
3. No image on LCD.
截圖 2021-11-18 下午10.15.43.png (366.09 KiB) Viewed 337 times
kw81634dr
Re: [Defect] Sharp 2.7 inch memory LCD
by adafruit_support_carter on Fri Nov 19, 2021 4:42 pm
Can you post another photo of the backside. It may be a connection issue where the ribbon cable goes in to the connector on the back.
by kw81634dr on Fri Nov 19, 2021 4:55 pm
Here it is, thx.
kw81634dr
by adafruit_support_carter on Fri Nov 19, 2021 5:07 pm
Thanks. That actually looks OK.
Any obvious damage to the ribbon cable itself? It looks OK from what can be seen in photo.
Try restaging everything in a different location on the breadboard and see if you still get the same behavior.
by kw81634dr on Fri Nov 19, 2021 7:48 pm
Thank you for the tips, I have tried couple times re-install the cable & make sure it goes all the way in to the receptacle every time. I guess there are nicks somewhere inside the cable, it conducts when I press.
I’m trying my best to prevent additional work for you and me, but unfortunately the problem still there, and it’s obviously a defective product. It’s been two days.
I would be appreciate if you could replace this item, instead of sending messages back and forth on the forum.
kw81634dr
by kw81634dr on Mon Nov 29, 2021 9:43 pm
Any updates? Thank you.
kw81634dr
by adafruit_support_carter on Tue Nov 30, 2021 12:42 pm
Sorry for the delay. Let's just replace this. Weird issue, but does seem potentially related to the ribbon cable.
Reply again via email to support@adafruit.com and link them back to this thread. They can send you a replacement display.
by kw81634dr on Tue Nov 30, 2021 1:17 pm
Hi, thank you for your reply, I replied to the customer support with a link and a screen shot just now, thank you.
kw81634dr
