Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days. On MLK Day no orders will be shipped.
Mini Analog Joystick
by Clickamouse on Sat Dec 04, 2021 10:02 am
Can you remove the springs from the Mini Analog Joystick Product ID: 3102 so that it remains where you set it?
Thanks...Mike
Clickamouse
Re: Mini Analog Joystick
by dastels on Sat Dec 04, 2021 10:43 am
On the product page it does say
You could replace the springs if you want a stronger or weaker spring-back force.
so they can certainly be removed entirely. However, I have no idea whether there's enough friction to have it stay in place.
dastels
by originalwarby on Fri Jan 07, 2022 6:18 pm
I recently received one of these and tried releasing the spring. It does stay put - mostly.
If you are near the end of travel, the rubber boot thingy on top that acts as a seal for dust/spills does provide some resistance such that if you move the joystick to the end of travel and then let go, the boot will push it back ~5-10 degrees.
It looks like you could trim the boot off carefully but of course, you wouldn't have a seal anymore.
HTH
Warby
I took a picture of the spring - one of the axis has been removed for a different purpose so don't be alarmed by the missing parts :)
Screen Shot 2022-01-07 at 2.18.52 PM.png (666.64 KiB) Viewed 41 times
originalwarby
by originalwarby on Fri Jan 07, 2022 6:31 pm
Here's a different question, I would love to use this joystick with an Apple ii Plus that I recently resurrected. The Apple ii requires 150k Ohm potentiometers and this comes with 10k potentiometers. I was able to disassemble the joystick complete including removing the potentiometer without having to cut/break anything (excellent design for tinkering with the joystick).
But I'm having trouble tracking down the manufacture of the potentiometer itself to source the 150k Ohm version. The only marking I can find is "B10K-50 (degree symbol)".
Looking at digi-key and similar, there are just too many options to filter effectively.
Anyone know how to find the source? Here are a couple of photos:
originalwarby
