Hi guys!
I need help, I’v done the project of using Gemma to trigger a blink in a Neopixels inside of a drum, and it went well, but, the drums trigger each other.
I’v tried to change the “NOISE” at the top of the code, but at some rate (after 440), not all of the led is triggered.
It doesn't matter how loud signal I'v put against the mic, after 440 NOISE less LED are triggered.
I only tried to change also number of pixels, didn’t help.
Running through Adafruit forum and searching for answers It seems like there is none, everyone writes to increase the NOISE, which didn't really work out.
I'v yet to try to cover the mic, but I really don't it will help much, since even at the highest NOISE setting the other drums light up really easily.
I would want to disconnect the mic and connect a piezo instead, but I am less than a newbie with codes, so I have no idea how to make a code for a piezo.
I would really appreciate if anyone could tell me if there is a solution for this inside the code, or if anyone could give me a code of triggering LED with a piezo through Gemma.
The code:
https://learn.adafruit.com/gemma-powere ... it-diagram
