Re: Low 8 channel shifter voltage reading
by donsatchell on Fri Jan 14, 2022 11:14 am
Attached is a picture of the level shifter test setup. VCCA is connected to a 3.2 volt DC source. VCCB and OE are connected to a 5 volt DC source. Then, the shifter ground is connected to the other grounds. I used a volt meter with the negative probe on the shifter ground solder bead and the positive probe on the VCCA, OE, and VCCB solder beads to confirm the voltages. Next the Teensy 4.1 provided a 3.2 volt signal to A1 that alternated between 3.2 and 0 volts every five seconds. I confirmed the voltage using my voltmeter with the negative probe on the shifter ground solder bead and the positive probe on the A1 solder bead. Then, I measured the B1 voltage using the same method. The voltage alternated between about 2.6 and 2.1 volts. I repeated the experiment with the A1 to A8 channels with similar results. Next, I repeated the experiment with two other 8 channel shifters that I received in the same order with similar results. I did not solder the fourth shifter to keep it available for any additional test that you might suggest. Then I repeated the experiment with a Sparkfun 4 channel and observed alternating voltages between 0 and 5 volts, as expected.
I can see only two explanations for these observations. Either a poor solder connection has resulted in poor communication with the board or the board is malfunctioning. The solder bead look good to me. In addition, I have never encountered problems with my soldering in the past.
- Attachments
- TestSetup.jpg (488.93 KiB) Viewed 63 times
