MLX90393
MLX90393
by mromeo12 on Fri Jan 21, 2022 1:53 pm
Hello I need an help with with the sensor MLX90393.
I use photon Argon anche I need to connect five of this sensor with Grove I2c 6 port https://www.kiwi-electronics.nl/nl/grov ... ugQAvD_BwE .
I have a problem with the i2C address of the sensor when I connect more than one sensors together.. How can I solve and read the measures from all the sensor at the same time?
Thanks a lot !
this code for a single sensor works:
// Distributed with a free-will license.
// Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
// MLX90393
// This code is designed to work with the MLX90393_I2CS I2C Mini Module available from ControlEverything.com.
// https://www.controleverything.com/products
#include <math.h>
// MLX90393 I2C Address is 0x0C(12)
#define Addr 0x0C
int xMag = 0, yMag = 0, zMag = 0;
int MagInt = 0;
void setup()
  // Set variable
  Particle.variable("i2cdevice", "MLX90393");
  Particle.variable("xMag", xMag);
  Particle.variable("yMag", yMag);
  Particle.variable("zMag", zMag);
  // Initialise I2C communication as MASTER
  Wire.begin();
  // Initialise serial communication, set baud rate = 9600
  // Start I2C Transmission
  Wire.beginTransmission(Addr);
  // Select Write register command
  Wire.write(0x60);
  // Set AH = 0x00, BIST disabled
  Wire.write(0x00);
  // Set AL = 0x5C, Hall plate spinning rate = DEFAULT, GAIN_SEL = 5
  Wire.write(0x5C);
  // Select address register, (0x00 << 2)
  Wire.write(0x00);
  // Stop I2C Transmission
  Wire.endTransmission();
  // Request 1 byte of data
  Wire.requestFrom(Addr, 1);
  // Read status byte
  if (Wire.available() == 1)
    unsigned int c = Wire.read();
  Wire.write(0x60);
  // Set AH = 0x02
  Wire.write(0x02);
  // Set AL = 0xB4, RES for magnetic measurement = 0
  Wire.write(0xB4);
  // Select address register, (0x02 << 2)
  Wire.write(0x08);
  // Read status byte
  delay(300);
void loop()
  unsigned int data[7];
  // Start single meaurement mode,  ZYX enabled
  Wire.write(0x3E);
  // Read status byte
  delay(100);
  // Send read measurement command, ZYX enabled
  Wire.write(0x4E);
  // Request 7 bytes of data
  Wire.requestFrom(Addr, 7);
  // Read 7 bytes of data
  // status, xMag msb, xMag lsb, yMag msb, yMag lsb, zMag msb, zMag lsb
  if (Wire.available() == 7);
    data[0] = Wire.read();
    data[1] = Wire.read();
    data[2] = Wire.read();
    data[3] = Wire.read();
    data[4] = Wire.read();
    data[5] = Wire.read();
    data[6] = Wire.read();
  // Convert the data
  xMag = data[1] * 256 + data[2];
  if (xMag > 32767)
    xMag -= 65536;
  yMag = data[3] * 256 + data[4];
  if (yMag > 32767)
    yMag -= 65536;
  zMag = data[5] * 256 + data[6];
  if (zMag > 32767)
    zMag -= 65536;
      MagInt = sqrt(xMag*xMag + yMag*yMag + zMag*zMag);
  Particle.publish("Magnetic Field in X-Axis : ", String(xMag));
  Particle.publish("Magnetic Field in Y-Axis : ", String(yMag));
  Particle.publish("Magnetic Field in Z-Axis : ", String(zMag));
   delay(1000);
  Particle.publish("Magnetic field Intensity: ", String(MagInt));
  delay(1000);
Last edited by adafruit_support_carter on Fri Jan 21, 2022 2:07 pm, edited 1 time in total.
Reason: added [code] tags
mromeo12
Re: MLX90393
by adafruit_support_carter on Fri Jan 21, 2022 2:11 pm
I2C requires each device on the bus have a unique address. You can set alternate addresses for the MLX90393 using the A0/A1 solder jumpers:
https://learn.adafruit.com/mlx90393-wid ... ter/pinout
However, this will only allow up to 4 unique addresses.
To get around address conflicts, and I2C muxer can be used:
https://learn.adafruit.com/adafruit-tca ... r-breakout
Re: MLX90393
by mromeo12 on Fri Jan 21, 2022 2:44 pm
I will use also this one? https://www.berrybase.de/it/sensori-mod ... ca9548a-41
But becouse I need only five ports, can I break the board?
mromeo12
Re: MLX90393
by adafruit_support_carter on Fri Jan 21, 2022 2:48 pm
The linked board uses the same TCA9548 muxer as the Adafruit board. So should work. You do not need to use all 8 ports.
Re: MLX90393
by mromeo12 on Fri Jan 21, 2022 2:50 pm
yes but is soo long. you think that I can break the blu part and use only 5 ports?
mromeo12
Re: MLX90393
by adafruit_support_carter on Fri Jan 21, 2022 2:54 pm
Unknown. You'd need to contact the vendor to determine if that is possible.
Re: MLX90393
by mromeo12 on Fri Jan 21, 2022 5:04 pm
okay thanks... have you ever use this multi with the argon?
mromeo12
Re: MLX90393
by adafruit_support_carter on Fri Jan 21, 2022 6:51 pm
I have not used that specific combination of hardware. But known no reason(s) why a TCA muxer should not work with MLX90393's.
