Hello everyone,
I posted this question on the Github page for the Adafruit BNO055 as well (https://github.com/adafruit/Adafruit_Ci ... hon_BNO055), but I wanted to check here to see if anyone has a simple fix.
I think I have found an issue with the WebGL demo of the BNO055 sensor. However, I want to confirm that this is just an issue with the example code and visualization, and not with the data collected from the sensor.
When I run the demo, the motion of the 3D model in the WebGL example does not reflect the motion of the BNO055 sensor. Specifically, with the sensor on a flat surface with the VIN to RST pin holes facing away, a change in pitch of the sensor (which accurately changes the values next to "Pitch =") causes the model to roll. A change in roll causes the model to yaw. And a change in yaw causes the model to pitch.
The system shows a complete calibration. Because the Euler output seems correct, I am guessing that there is some issue with the order of the quaternions in the code, but I have not been successful with identifying the exact issue.
I have tested this with two sensors, using both a direct soldered connection and a QWIIC connector, to my Raspberry Pi Zero 2. Because the video included with the tutorial seems correct (https://learn.adafruit.com/adafruit-bno ... ion-sensor), I think it might be related to the recent updates with the code hosted on the Github page, but I cannot be sure.
Thank you for any help!
