JST Connector Options for 4 Ohm Speaker Set (#1669)
- sealyon
Trying to determine if the JST connector used on this Speaker Set (#1669) is actually compatible with the standard JST-PH connector. The description just says the connector is similar to JST-PH but doesn't provide any links to Adafruit JST-PH cables. Can anyone confirm that the standard JST-PH cables offered by Adafruit will connect with this cable? And, if possible, please provide links to matching cable options from Adafruit. Appreciate any help.
- tepalia02
Re: JST Connector Options for 4 Ohm Speaker Set (#1669)
Yeah it's really a bit unclear. Because the pitches of adafruit's JHT-PH connectors( https://www.adafruit.com/category/598 ) are not mentioned. I think it will be better if the pitches are mentioned in the product's description.
- adafruit2
yes it is compatible with JST PH 2mm pitch
it is documented in the product page:
" (the connectors are similar to the JST-PH series which is ~2.0mm spacing)."
- sealyon
Ok, thanks. Would be better if it didn't just say "similar" but said that is the correct connector. And it would be good if links were added to the exact connectors to purchase.
