seems to be not compatible with the QT Py RP2040 board.
- Code: Select all | TOGGLE FULL SIZE
Error message: "Adafruit MPU6050 test! Failed to find MPU6050 chip"
I guess this is because the QT Py RP2040 uses I2C1 to communicate with the MPU6050, but the example code uses I2C0.
The I2C scanner test detects the MPU6050 correctly.
Scanning...
I2C device found at address 0x68 !
done
