Would you be so kind as to give me a little direction.
In an attempt to switch my products from raspi gpio to adafruit usb gpio.
The main task is to send PPM signal to a speed controller (flipsky 75200 esc)
On raspberry pi i do it like this.
import pigpio #importing GPIO library
pin=18 #Connect the ESC in this GPIO pin
pi = pigpio.pi();
max_value = 2500 #ESC's max value
min_value = 500 #ESC's min value
pi.set_servo_pulsewidth(pin, 1500) #initial setup
# set vv to a speed from 500 to 2000
pi.set_servo_pulsewidth(pin,vv) # change speed
What would be the equivalent code to perform pulse width on the product
i just ordered?
This would be so much help if anyone you can steer me in the right direction
I prefer nodejs however python is ok if no nodejs.
Basically trying to send ppm signal via gpio to control pulse with in range of 1 to 20ms
MCP2221A Breakout - General Purpose USB to GPIO
- tinkertiger
- tinkertiger
Re: MCP2221A Breakout - General Purpose USB to GPIO
No replies is very frustrating. since there is not much online supporting nodejs and adafruit i'm stuck
- Franklin97355
- tinkertiger
no sir it does not. in fact im so frustrated now i just gave up. Its just adding complexity where it doesnt need to be.Franklin97355 wrote:Does this help?
- sj_remington
The MCP2221A is not designed or intended for uses like generating PWM pulse trains.
USB servo controllers are available, such as the Pololu Maestro.
- adafruit2
MCP2221 absolutely does not support PWM output - you cannot use it for such a purpose! only I2C, UART, and GPIO
[MOD EDIT] removed mention of SPI, which MCP2221 does not support. The FT232H does though: https://www.adafruit.com/product/2264
- adafruit_support_carter
Also several I2C based options based on the PCA9685. No MCP2221A needed. All Pi's have I2C available on the GPIO header.
HAT:
https://www.adafruit.com/product/2327
Bonnet:
https://www.adafruit.com/product/3416
Breakout:
https://www.adafruit.com/product/815
HAT:
Bonnet:
Breakout:
- tinkertiger
Its not pwm its PPM SIGNAL .. however this mcp2221 DOES SUPPORT DAC so i can throw the signal to the vesc that way. already got it working will test on motor tomorow. only 32 settings but i think doable 'rather have it be 8 bit' than 5bit precision .adafruit2 wrote:MCP2221 absolutely does not support PWM output - you cannot use it for such a purpose! only I2C, UART, and GPIO
Is there any script where i can also hook up HMC5883L compass via SDA/SDL ETC on MCP2221
I do not see any python script for this but looks like it should work?? Any solution to adding my compass?
This is pretty exciting now. If i cant do hmc5883l compass with mcp2221 is there another USB/PYTHON solution from adafruit?
thanks!
It would be possible if there were a Python (or CircuitPython) library available. However, the HMC5883L is an older and now discontinued product:
https://www.adafruit.com/product/1746
and there is only an Arduino library available:
https://github.com/adafruit/Adafruit_HMC5883_Unified
The MCP2221 simply provides the I2C bus. If you can find a Python library for the HMC5883L that allows passing in an arbitrary I2C bus instance, then it might work.
- tinkertiger
HOW? can you see if one exists I am not a programmer . just point me to a script or if you have another way i can get my compass input via another product that has KNOWN SCRIPT that would be helpful too i will buy that too.adafruit_support_carter wrote:It would be possible if there were a Python (or CircuitPython) library available. However, the HMC5883L is an older and now discontinued product:
- adafruit2
these compasses
https://www.adafruit.com/product/4488
https://www.adafruit.com/product/4413
https://www.adafruit.com/product/4479
should be workable as they have python drivers
- tinkertiger
None seem to be usb :( i want to use laptopadafruit2 wrote:these compasses
They can be used in conjunction with the MCP2221A. The MCP is what provides the USB to I2C bridge for talking to the I2C based sensors from a PC's USB port.
