Time of flight sensor inside weatherproof enclosure
by Leptir on Sun Jul 03, 2022 3:14 am
I need a sensor to measure distance outdoor (up to a few meters).
I was thinking about the VL53L1X Time of Flight Distance Sensor and I was thinking to mount it inside an enclosure with a clear polycarbonate top (this one).
Would that work? I mean, would the polycarbonate top interfere?
Also, not that it rains often in Southern California, but would rain cause interference?
Thank you!
Leptir
Re: Time of flight sensor inside weatherproof enclosure
by adafruit_support_bill on Sun Jul 03, 2022 9:17 am
Polycarbonate in general has good transmission in the IR range so it should work. The datasheet describes the calibration that must be performed when the sensor is used behind a protective cover. Search for "cover glass".
https://cdn-learn.adafruit.com/assets/a ... 1634930163
Rain is another story. raindrops on the polycarbonate cover would act as little lenses and disperse the beam. A few drops probably wouldn't render it useless, but a heavy rain might.
by Leptir on Mon Jul 04, 2022 12:13 am
adafruit_support_bill wrote:Search for "cover glass".
Thank you!
Leptir
