PiGRRL Zero - alternatives to tactile buttons?
t0r1n
Post by t0r1n »
Hey guys,
Im currently building a PiGRRL Zero. I built the PiGRRL 2.0 and love it. As Im getting ready to build the new one, I would really like less "clicky" buttons. Not knowing much regarding terminology for press button switches, what should I be looking for? Specifically I am looking for something closer to what would be used in a typical controller. That being said, I do realize that typical controllers generally don't use anything similar to whats in the kit. My hope would be to find a type of 4mm switch I could use to replace the tactile ones in the kit that would give a more controller like feel. Any help / pointers would be greatly appreciated. Thanks!
-Ryan
adafruit_support_mike
Re: PiGRRL Zero - alternatives to tactile buttons?
A controller uses flexible membrane buttons like we have for the Trellis:
https://www.adafruit.com/products/1611
Those are a favorite of companies already doing injection molding anyway, but each one is custom-formed for the product it goes into. They don't exist as discrete devices.
You can chop up a controller and connect the switches to the RasPi (that's what the PiGrrl proect does), or you can hit Digikey and Mouser looking for low activation force tact switches.
t0r1n
Post by t0r1n »
I think ill give butchering up a SNES controller and modifying the case a go. If I have any luck Ill post the results. Thanks!
-Ryan
t0r1n
Post by t0r1n »
I have not had a chance to butcher up a SNES controller yet. I was looking at the website today and saw https://www.adafruit.com/products/3101 . Looks like these are exactly what I needed!!!! Thought I would post this in this thread in case anyone else is looking for a similar solution!
Thanks guys!
Yep, we just added those.
aspiringnobody
Post by aspiringnobody »
Those tac switches don't fit on the version of the PCB I received with my kit. They work for the dpad but won't fit on the action buttons.
- Evan
aspiringnobody
aspiringnobody wrote:Those tac switches don't fit on the version of the PCB I received with my kit. They work for the dpad but won't fit on the action buttons.
- Evan
I take that back, I was able to get them to fit, but it's super sketchy. you need to insert X and B first, and then when you insert Y and A you'll have to bend the pins sideways in towards the center. I'm still waiting on parts to finish so I don't know how they actually work being slightly out of place. I'll update next week when I get the rest of the parts I need to boot it up.
