Adafruit Feather M0 Adalogger button press state change
pripri804
Post by pripri804 »
I'm trying to get the led to change it's state when the button is pressed on my feather M0, but somehow it is not working.
This is the circuit
This is the code:
const int  buttonPin = 2;    // the pin that the pushbutton is attached to
 const int ledPin = 13;       // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
   // initialize the button pin as a input:
   pinMode(buttonPin, INPUT);
   // initialize the LED as an output:
   pinMode(ledPin, OUTPUT);
   // initialize serial communication:
   // read the pushbutton input pin:
   buttonState = digitalRead(buttonPin);
   // compare the buttonState to its previous state
   if (buttonState != lastButtonState) {
     // if the state has changed, increment the counter
     if (buttonState == HIGH) {
       // if the current state is HIGH then the button
       // wend from off to on:
       buttonPushCounter++;
       Serial.println("on");
       Serial.print("number of button pushes:  ");
       Serial.println(buttonPushCounter);
     } else {
       // if the current state is LOW then the button
       // wend from on to off:
       Serial.println("off");
     // Delay a little bit to avoid bouncing
     delay(50);
   // save the current state as the last state,
   //for next time through the loop
   lastButtonState = buttonState;
   // turns on the LED every four button pushes by
   // checking the modulo of the button push counter.
   // the modulo function gives you the remainder of
   // the division of two numbers:
   if (buttonPushCounter % 4 == 0) {
     digitalWrite(ledPin, HIGH);
   } else {
     digitalWrite(ledPin, LOW);
What could be the issue ?
Re: Adafruit Feather M0 Adalogger button press state change
What exactly does it do when you press the button? What is the output on the serial monitor?
pripri804
Post by pripri804 »
Nothing - nothing happens.
However, I tried outputting the value of digitalRead(buttonPin) onto the serial monitor and I've noticed that it returns 1 if the button is connected and 0 if not. Pushing the button doesn't affect this at all, it still returns 1 regardless of the button's state.
It sounds like either a bad button, or you have it wired wrong. Test the button out of the circuit with a multimeter. Typically with a 4-pin button, the pins are connected internally in 2 sets of 2.
pripri804
Post by pripri804 »
I have tested the button and I've made sure that the board is wired correctly. Now I've also found out that whether or not the button is plugged in, the println still keeps on outputting the same value. (1)
Please post an actual photo of your circuit.
pripri804
Post by pripri804 »
Here they are:
It looks like you have the switch connected to digital pin 16 or 17, but your code is reading from pin 2.
pripri804
Post by pripri804 »
Hi, yes the problem was actually a wrong pin number in my code. Thank you, the program is now functioning as intended.
