🐍 CircuitPython is the easiest way to program microcontrollers now celebrating over 200 boards!🐍
Speed control for Adafruit 16-Channel 12-bit PWM/Servo Drive
by 30ppp on Wed Aug 10, 2016 8:17 am
Hi
Recently I bought "Adafruit 16-Channel 12-bit PWM/Servo Driver - I2C interface - PCA9685" board for my Arduino Uno. (https://www.adafruit.com/products/815)
But I can't find ant way to control the servo speed.
The only method that I found is setPWM that there is no parameter as speed control for it.
any idea?
30ppp
Re: Speed control for Adafruit 16-Channel 12-bit PWM/Servo D
by adafruit_support_bill on Wed Aug 10, 2016 8:27 am
Seek speed is a function of the servo - not the controller. If you want to seek slower, you need to do an incremental seek.
by 30ppp on Wed Aug 10, 2016 8:31 am
Thanks for your replay.
Cant you please give me an example ?
30ppp
by adafruit_support_bill on Wed Aug 10, 2016 10:39 am
The example included with the library does an incremental seek.
  for (uint16_t pulselen = SERVOMIN; pulselen < SERVOMAX; pulselen++) {
    pwm.setPWM(servonum, 0, pulselen);
If you want to change the speed, you can add a delay in the loop:
    delay(5);
by 30ppp on Wed Aug 10, 2016 12:45 pm
There is problem with that.
If I have many servos and I want theme to run simultaneously and each of them have different pulselen upper code won't work at all and they will work sequential.
30ppp
by adafruit_support_bill on Wed Aug 10, 2016 12:56 pm
by 30ppp on Sun Aug 21, 2016 3:16 pm
Thank you.
It worked properly !
30ppp
