TYVM for your quick response Franklin...
Now with this code...
#include <SPI.h>
#include <Adafruit_WINC1500.h>
#include <Adafruit_GPS.h>
//#include <SoftwareSerial.h>
// put your setup code here, to run once:
// put your main code here, to run repeatedly:
I see this message....
Arduino:1.6.9 (Mac OS X), Tarjeta:"Arduino/Genuino Uno"
ATENCIÓN: .github BANNED carpetas en BANNED 'Adafruit_WINC1500'
Atención: platform.txt del BANNED 'Arduino AVR Boards' contiene recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" desfasada, automáticamente convertida a recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{preprocessed_file_path}". Considera el actualizar este BANNED.
/Users/pedrominguillanrenaut/Library/Arduino15/packages/arduino/hardware/avr/1.6.9/libraries/SoftwareSerial/SoftwareSerial.cpp:375:6: warning: always_inline function might not be inlinable [-Wattributes]
void SoftwareSerial::setRxIntMsk(bool enable)
/Users/pedrominguillanrenaut/Library/Arduino15/packages/arduino/hardware/avr/1.6.9/libraries/SoftwareSerial/SoftwareSerial.cpp:121:6: warning: always_inline function might not be inlinable [-Wattributes]
void SoftwareSerial::recv()
libraries/SoftwareSerial/SoftwareSerial.cpp.o: In function `__vector_3':
/Users/pedrominguillanrenaut/Library/Arduino15/packages/arduino/hardware/avr/1.6.9/libraries/SoftwareSerial/SoftwareSerial.cpp:227: multiple definition of `__vector_3'
libraries/Adafruit_WINC1500/bsp/source/nm_bsp_arduino_avr.c.o:/Users/pedrominguillanrenaut/Documents/Arduino/libraries/Adafruit_WINC1500/src/bsp/source/nm_bsp_arduino_avr.c:69: first defined here
libraries/SoftwareSerial/SoftwareSerial.cpp.o: In function `SoftwareSerial::read()':
/Users/pedrominguillanrenaut/Library/Arduino15/packages/arduino/hardware/avr/1.6.9/libraries/SoftwareSerial/SoftwareSerial.cpp:392: multiple definition of `__vector_4'
libraries/Adafruit_WINC1500/bsp/source/nm_bsp_arduino_avr.c.o:/Users/pedrominguillanrenaut/Documents/Arduino/libraries/Adafruit_WINC1500/src/bsp/source/nm_bsp_arduino_avr.c:62: first defined here
/Users/pedrominguillanrenaut/Library/Arduino15/packages/arduino/hardware/avr/1.6.9/libraries/SoftwareSerial/SoftwareSerial.cpp:392: multiple definition of `__vector_5'
collect2: error: ld returned 1 exit status
exit status 1
Error compilación en tarjeta Arduino/Genuino Uno.
Este reporte BANNED tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
Whats happens?
But when I comment this line
this is the message show...
El Sketch usa 744 bytes (2%) del espacio de almacenamiento de programa. El máximo es 32.256 bytes.
Las variables Globales usan 77 bytes (3%) de la memoria dinámica, dejando 1.971 bytes para las variables locales. El máximo es 2.048 bytes.
What I can to do solve this little problem?
I greatly appreciate the help you're offering me.
I am very happy with your products and above all eager to start my project.
Awaiting your news receives a warm greeting.
