Comparing the output of two MAX4466's
Re: Comparing the output of two MAX4466's
by zheng3 on Sat Aug 27, 2016 10:10 am
right mic: pin 0 left mic pin 1:
right mic: pin 1 left mic pin 0
And just to see if it's pin 0 that's somehow gone bad, I tried with pins 2 and 3 instead.
right mic: pin 2, left mic pin 3
and swapping 2 and 3 reverses the results.
zheng3
by adafruit_support_bill on Sat Aug 27, 2016 1:02 pm
Not sure which trace corresponds to which pin, but it seems like the problem follows the microphone when you swap pins. One of the microphones only responds when tapped & the other responds when either is tapped - regardless of the pin connections. Is that accurate?
If you post some close-up photos of both boards, we can check them over for any manufacturing or assembly problems.
by zheng3 on Sat Aug 27, 2016 3:05 pm
Yes, that is correct.
zheng3
by adafruit_support_bill on Sat Aug 27, 2016 3:19 pm
No obvious problems there. Let's try replacing the 'B' microphone. Please contact support@adafruit.com with a link to this thread and we can get one out to you.
by zheng3 on Sat Aug 27, 2016 3:37 pm
Replacing B is a good idea, I'll send this thread over to support.
I've actually got another microphone (let's call it C) already here ready to go. Take a look at these plots.
zheng3
by adafruit_support_bill on Sat Aug 27, 2016 3:53 pm
OK. I think I see the problem now in the code:
This is how the min and max are initialized:
       unsigned int signalMax = 0.0;
       unsigned int signalMin = 1024.0;
But they are not re-initialized before the second sample. So the second sample will always be at least as high a reading as the first sample.
You need to add this between the first and second samples:
       signalMax = 0.0;
       signalMin = 1024.0;
by zheng3 on Sat Aug 27, 2016 4:06 pm
In the end, so simple. Thanks so much, Bill. I've learned a great deal in the last couple of days thanks to you.
Here's the working code should someone else stumble upon this thread with a similar issue.
    Example Sound Level Sketch for the
    Adafruit Microphone Amplifier
    const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
    unsigned int sample;
    void setup()
       pinMode(A2, INPUT);
       pinMode(A3, INPUT);
    void loop()
       unsigned long startMillis= millis();  // Start of sample window
       double peakToPeak = 0;   // peak-to-peak level
       // collect data for 50 mS
       while (millis() - startMillis < sampleWindow)
          sample = analogRead(2);
          if (sample < 1024)  // toss out spurious readings
             if (sample > signalMax)
                signalMax = sample;  // save just the max levels
             else if (sample < signalMin)
                signalMin = sample;  // save just the min levels
       peakToPeak = signalMax - signalMin;  // max - min = peak-peak amplitude
       double volts0 = (peakToPeak * 5.0) / 1024.0;  // convert to volts
       signalMax = 0.0;
       signalMin = 1024.0;
          sample = analogRead(3);
       double volts1 = (peakToPeak * 5.0) / 1024.0;  // convert to volts
        Serial.print(volts0);
        Serial.print(",");
        Serial.println(volts1);
zheng3
by adafruit_support_bill on Sat Aug 27, 2016 4:26 pm
Excellent! Are you able now to distinguish between sounds from the right and left?
by zheng3 on Sat Aug 27, 2016 4:34 pm
Even better! left, right, and middle.
I'll be using these mics to drive servo rotation on Plutarch, my robot parrot: http://zheng3.com/2016/06/16/plutarch-1-0-finished-still-not-a-robot/
With a little more work, he'll be able to look towards and react to the loudest sound in his environment.
zheng3
by adafruit_support_bill on Sat Aug 27, 2016 8:49 pm
That's pretty awesome. Hope that your robo-parrot performs as expected.
