Working with the 16mb version fo the Sound FX Board, and I'm having issues with it recognizing the files on it. I've tried re-imaging it and using the demo tracks as well. Basically what happens when I trigger the pins is... nothing. Pin #0 triggers to a "Left/Right" test, however the others do nothing. It worked one power cycle with my own files, though pin #7 triggered the "Left/Right" test instead of the designated file. Appreciate any help that you can offer.
Sound FX board not working
- Franklin97355
Re: Sound FX board not working
What are the file names and how are you powering the board?
- kyjeepguy
When I used my own files they were simply Txx.wav, the demo tracks are as they came in the zip file. I'm powering it with a 5v iPhone charger.franklin97355 wrote:What are the file names and how are you powering the board?
- kyjeepguy
Any ideas? Otherwise I'll just return it for an exchange and try again.
- adafruit_support_rick
Can you post a screenshot of the directory?
You don't have the USB plugged in when you're trying to trigger it, do you?
Is there anything in the trash? Sometimes that confuses it.
- kyjeepguy
adafruit_support_rick wrote:Can you post a screenshot of the directory?
Hey Rick. I've emptied trash, and even re-imaged it. It's not connected as a USB device when triggering, It's connected to an apple 5.0v wall adapter and a quality USB cable. The directory is simply the demo files at this point, but I've attached a screenshot for you.
It had troubles being recognized by a computer the first time I hooked it up. I tried a few times on my mbp and it didn't show up, then I connected it to my PC and it recognized it. After that, the MBP recognized it fine.
Thanks for you help!
- Attachments
- Directory of sound board
- Screen Shot 2016-10-26 at 2.11.41 PM.png (128.63 KiB) Viewed 167 times
I don't know. Let's try replacing it
Please email [email protected] with a link to this thread for a replacement
- kyjeepguy
adafruit_support_rick wrote:I don't know. Let's try replacing it
Rick:
After posting that, I went back and did a fresh re-image again, and it seems to be working fine now! So odd, but thank you for your help!
