Barcode Reader/Scanner - PS/2 Help with Configuration
by vchinta on Mon Nov 14, 2016 1:14 pm
I recently purchased a Barcode Reader/Scanner with PS/2 interface from Adafruit (link - https://www.adafruit.com/products/1202).
I'm having trouble configuring it to work in other modes - continuous, auto power on, flash etc. Trouble in the sense I am not able to configure the reader to work in any mode other the default.
I just wanted to find out if I'm doing it wrong before I decide I may have received a defective piece. This is how I'm trying to configure:
1. Scan Start of configuration barcode
2. Scan Continuous mode barcode
3. Scan End of configuration barcode
4. Scan Save parameters barcode
But the device always stays in the default mode. I have to physical press that small button on the top to read a code. Please help.
vchinta
Re: Barcode Reader/Scanner - PS/2 Help with Configuration
by adafruit_support_rick on Fri Nov 18, 2016 12:19 pm
Try this:
Start Configuration
Continuous/Trigger Off
End Configuration
Now press the trigger button. Does the light stay on?
by vchinta on Fri Nov 18, 2016 1:37 pm
I did try it. And the light does not stay on.
You can find a video of my trial here: https://drive.google.com/file/d/0Bwew736KYms5WDJFZDBZSnJWUHM/view?usp=sharing so you can verify if I'm doing anything else wrong.
Can this mean the device is faulty?
vchinta
by adafruit_support_rick on Fri Nov 18, 2016 10:10 pm
Weird. Mine doesn't act that way. We can try replacing it. Please email support@adafruit.com with a link to this thread for a replacement scanner
by vchinta on Wed Nov 30, 2016 4:34 pm
Hi! I received a replacement for my barcode scanner and this unit behaves the same way too.
I must be doing something wrong. From what I understand, as long as Vcc and Gnd are connected appropriately, the programming codes should work. Correct?
I tried both Host Data and Host Clock connected & disconnected. (according to their pin out description for MiniDIN 6 Male connector in the manual, though I would think it might actually be KB Data and KB Clock)
The reader scans everything fine but just refuses to get programmed.
When I scan the Version Information code, is it supposed to spit out what it scanned or what its version is? It just spits out the version information code (%$+/5) back to me.
Can you attach a picture/schematic of all your connections if the connections in fact matter? The only other reason I can think of is that the Manual present in the page might be out of date. But I know you guys would have changed it by now if that was the case.
I am using this in a project for a class and have my presentation is due this Friday. This is the only component left that I have to incorporate.
I expected, from the product description, that it is going to be a breeze to use this but my experience so far has been frustrating at best. Please reply soon.
Thank you,
Venkat
vchinta
by adafruit_support_rick on Thu Dec 01, 2016 11:04 am
Try Continuous/AutoPowerOn or Flash/AutoPowerOn
by vchinta on Mon Dec 05, 2016 2:27 pm
Still does not work. I tried both. I tried all.
I even tried just to turn off the beeper. Doesn't work.
vchinta
by adafruit2 on Mon Dec 05, 2016 9:10 pm
are you able to get barcode data out of it in PS/2 mode in general?
adafruit2
Site Admin
by vchinta on Mon Dec 05, 2016 9:16 pm
Yes I am. It reads everything perfectly. Even the programming codes. But that's my problem, even though it reads the programming barcodes, it doesn't get programmed!
vchinta
by adafruit2 on Mon Dec 05, 2016 9:20 pm
huh maybe they changed. can you check to see if these barcodes are different in the product downloads?
http://www.champtek.com/product.php?id=175
adafruit2
Site Admin
by vchinta on Mon Dec 05, 2016 9:43 pm
I checked the ones I have been using and they are the same.
vchinta
by adafruit2 on Mon Dec 05, 2016 10:37 pm
ok we'll ask the company for any details, not sure when they'll reply - you can also try http://www.champtek.com/contact_us.php
adafruit2
Site Admin
by vchinta on Mon Dec 05, 2016 10:42 pm
I've already sent them a query. Waiting for their reply.
vchinta
by vchinta on Mon Dec 05, 2016 10:44 pm
If you have a working piece with you, even if it's not brand new, can you please ship that me? Please. I cannot tell you how urgently I need this done. Semester ends 12th and I need a working prototype by then! =|
vchinta
by adafruit2 on Tue Dec 06, 2016 12:01 am
we only have the exact same item you have now
adafruit2
Site Admin
