New VL53L0X not working
Re: New VL53L0X not working
by Herculoser on Sat Jul 27, 2019 8:33 am
Hi I'm having an issue with one of 2 new sensors. One works but when I unplug it and try the other sensor it doesn't show up.
Using the Adafruit vl53l0x example code, one works and the other gives me these error messages:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 17108 bytes (53%) of program storage space. Maximum is 32256 bytes.
Global variables use 1236 bytes (60%) of dynamic memory, leaving 812 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\\.\COM6": The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
processing.app.SerialException: Error opening serial port 'COM6'.
at processing.app.Serial.<init>(Serial.java:147)
at processing.app.Serial.<init>(Serial.java:82)
at processing.app.SerialMonitor$4.<init>(SerialMonitor.java:101)
at processing.app.SerialMonitor.open(SerialMonitor.java:101)
at processing.app.AbstractMonitor.resume(AbstractMonitor.java:104)
at processing.app.Editor.resumeOrCloseSerialMonitor(Editor.java:2126)
at processing.app.Editor.access$1300(Editor.java:115)
at processing.app.Editor$UploadHandler.run(Editor.java:2104)
at java.lang.Thread.run(Thread.java:748)
Caused by: jssc.SerialPortException: Port name - COM6; Method name - openPort(); Exception type - Port not found.
at jssc.SerialPort.openPort(SerialPort.java:167)
at processing.app.Serial.<init>(Serial.java:136)
... 8 more
I've tried re-soldering the board to see if that's the issue but had no luck.
Hope it's okay to jump in on this post but I couldn't seem to start a new one. Do you have any suggestions? All I can think is that the board may be faulty.
Herculoser
by franklin97355 on Sat Jul 27, 2019 1:01 pm
The error says it can't communicate with the Uno. if you remove the VL53L)X does it upload?
franklin97355
by Herculoser on Sat Jul 27, 2019 5:21 pm
Yes it uploads fine without this particular vl53l0x or anything else plugged in. As mentioned above, it works fine with another vl53l0x that I have (I'm hoping to use them together), it's just this one that I can't seem to get any response from.
Herculoser
by franklin97355 on Sat Jul 27, 2019 5:43 pm
OK, we'll see what a new one will do Please contact support@adafruit.com with a link to this topic and they will get you a replacement.
franklin97355
by Herculoser on Sun Jul 28, 2019 8:19 am
Great, thank you!
Herculoser
by jonayabascal on Thu Aug 06, 2020 8:29 am
Enfrenté tal problema en VL53L0X. Resolví el problema de manera similar, encontré información sobre el recurso
jonayabascal
