Also, my last question hahah. Is it bad to power the adafruit board with 12v= 2A? Plus on the v+ pin and black on the gnd pin.
Thank you!
Adafruit Huzzah ESP8266 no output voltage to light up ledstr
- joeMartin
- adafruit_support_carter
Re: Adafruit Huzzah ESP8266 no output voltage to light up le
Note from bottom of product page:
Revision history: as of May 15, 2016 we have changed the power supply to run from a 6V DC max rather than 12V. At 12V the power supply would overheat anyways!
- joeMartin
Didn't read that one, I'll keep that in mind! Thank you!
- joeMartin
The adafruit gives an error when uploading.
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
First it worked fine, but suddenly it gives this error.
What could it possibly be?
Post question in a new topic. Provide more details of what changed to go from working to not working. Photos of your setup are also helpful - things have probably changes since your last post.
- joeMartin
It already works for some reason! I just tried it in another pc and the problem was fixed! Thank you!
